I figured this was a good place to post the storage system I just finished for my LJ.
It’s not really finished, probably more like a work in progress.
I started with a base board of 3/4 Baltic birch to give myself some flexibility in mounting or tying down a variety of options.
In this picture you can also see version 3 of my cargo basket mounting method. This basket has proven to be very handy for camping. It’s been one of my favorite mods. If anyone is interested I can provide the details on this basket.
In order to mount the base board I first removed the rear seat, seat mounting brackets, and center seat belt anchor, but left the carpet in place. I fastened 1” spacer blocks to the board in the appropriate places so that the base board is just barely resting on the carpet but mounted solidly to the tub.
The board is secured to the Jeep tub in seven places using the factory threaded inserts. No new holes were drilled and replacing the seat is quite easy if I need or want to.
Here is the drawer and drawer outer box I built to hold the normal, everyday on and off road gear. The Jeep spends quite a bit of time at various hiking trailheads both popular and remote here in AZ. My idea was to keep the gear at least out of sight and a little more secure than just strapped down in the back.
The center panel in the drawer is fixed to add strength while the rear divider is removable or adjustable. I decided not to use slides. The drawer rides on two runners of 1/8” hardboard that have been lubed with a spray, dry lubricant that I use on my woodworking machine tables. It slides very nicely even when fully loaded. In these pics you can also see the tie down rings on the sides of the drawer box. These can be adjusted to 5 different locations along each side to help tie down misc. camping gear if required.
Yeah, the Mahogany drawer front is overkill, but since I was kinda copying Rayra’s excellent suburban drawers I figured why not. I didn’t use a locking latch because, realistically, any security comes from the fact that even if someone breaks into the Jeep they still have to get the gate open. This “should” at least slow them down.
Here I’ve mounted the fridge slide next to the drawer box. The slide won’t ride in the Jeep full time, only when I use the Jeep for camping
As I said before, this is a work in progress. Even though I have the tie down tracks available along the forward edges of the base board I may “steal” BritKLR’s idea and drill some 1” holes in various locations to allow camping gear to be secured with roller cam straps. These would be especially usefull if the fridge wasn’t installed. Next project is to build a simple box that will mount forward of the drawer box to hold a MWC or two.
Thanks to all for the ideas on my current storage solution.
