preliminary electrical drawing for scrutiney
dwh
Tail-End Charlie
until I went looking at battery chargers and visited battery tenders web site FAQ area and saw that setup on the "hooking up" battery charger page
http://batterytender.com/resources/connecting-batteries-chargers.htm
Figures, 9, 11 and 13 on that page will result in the abbreviated power flow path that I showed in the edited drawing of your pic.
They are however, the "quick and easy" method of hooking up multiple batteries. The quick and easy method is not always the best method.
bansil
Cool so I will go with my original plans for the battery hookup(the cheez wiz one)
And will look into the switch you mentioned also
Since we are on the battery topic:
The batteries will be bolted to the floor
,my plan was to build a vented box to house the batteries and then have the bus bars(machined copper with lugs etc) mounted to outside the box,with cables attatched on inside of box,with studs passing thru box to the bus bars,so box will be sealed from the cabin area
I was going to vent the top to the outside(with screen on it)
and run a vent(screened) into and along the bottom of the box to equalize the air movement
I was thinking 3/4in pvc tube
would this be enuf vent for 4 batteries?
Sorry for all the questions
dwh
Tail-End Charlie
So all 6 cables need to be the same; say with-in 1/4-1/2 inch?
Thank you again for all the Neewbe help
All 6 cables don't need to be the same.
What needs to be identical, is the resistance of the two series strings. So if you have 3' of +/- from the series string to the bus bar, and 1' from - to + in middle of the string, then the other string needs to be the same as that.
The closer the total resistance of the entire series strings are to identical, the better. Even a quarter or half inch difference in cable length can change the resistance measurably. Hell, one bad crimp can do that too.
Whichever string has the lower resistance, will end up doing more work and wearing out sooner.
It is of course, impossible to achieve perfection. People with big battery banks generally make it a habit to swap the batteries around to different positions once in a while.
Captm
What would be the point of having a high output alternator? The tow package on my Taco it has an "upgraded" 140 amp alt. , how do I check the amp output on my alt.
Thanks!
Captm
Thanks, I knew you would have the answer. So the battery will only absorb X amps untill a load is put on it and then it will accept the required amps needed? Am I on the right path? (Pun not intended, but I'll go with it) . Cheers
dwh
Tail-End Charlie
Not exactly. The loads have no direct effect on how much amperage the battery will allow to flow through it.
The voltage regulator turns on the alternator to supply power to hold the "12v bus" at a certain voltage. Once the bus gets to that voltage, the regulator switches off the alternator. This is usually a range; i.e., switch it on at say 13.5v, and off at 14.5v. The switching happens quickly, so to the naked eye, it appears to be holding the bus at a more or less steady voltage.
If the battery voltage is below whatever voltage the bus is at, then the voltage (pressure) of the bus will cause some power to flow (push) through the battery. How much? Depends on the resistance of the battery, the resistance of the wire, and how much voltage differential there is between the bus, and the battery.
Let's say the battery will allow 10a of current to flow through it at whatever voltage the bus is at. Well, then the alternator is producing 10a because the battery is drawing 10a from the bus, and that pulls down the bus voltage and so the voltage regulator keeps the alternator switched on to hold the bus voltage up - but since there is only 10a being drawn from the bus, only 10a will be flowing from the alternator to the bus.
If you then turn on the lights, the auxiliary lights, your 12v air compressor, etc., etc., you might add another 50a of load to the bus. The loads will pull the bus voltage down (suck the pressure out), so the voltage regulator will switch the alternator on to supply power to keep the bus voltage up.
In this example, the load would be 10a + 50a = 60a. So if you had a 30a alternator, it would not be able to produce enough power to hold the bus voltage up, in that case, the loads would draw the bus voltage down below the battery voltage, and so power would flow from the battery to the bus.
The load on the bus would be 60a, and if the alternator can supply 30a of that, then the other 30a will flow out from the battery to the bus - until the battery is dead. Turn off some things and get the load down to say, 20a...then there would be an extra 10a available from the alternator to feed the battery, and since the battery's voltage is below the bus voltage, the battery will now be a load on the bus, and power will flow through the battery again, recharging it.
But if the bus voltage is at a (more or less) steady 14v - then the resistance of the battery is only going to allow X amps to flow through it at that pressure.
And the resistance of the battery changes. The resistance is highest when the battery is low, and also when the battery is almost full. If you take a regular ol' benchtop battery charger, with one of the analog meters, and hook it up to a dead battery, what you see is that only maybe 1a flows at first. After a while, it slowly goes up until it reaches some point - say 10a - and it stays there for some hours, and then slowly drops back down to 1a again.
That is exactly what happens with a normal alternator/voltage regulator setup charging a battery. The amount of amps that will flow through the battery, is controlled BY the battery.
If you want more amps to flow through the battery, you have to kick up the voltage to create a greater pressure differential, but you can't because the voltage regulator is hard wired to a certain voltage range. There are special voltage regulators though... :)
Even if the alternator can potentially* produce 160a, it won't unless there is something pulling 160a out of it. It will only produce however many amps are being drawn from it.
Same thing with the main breaker box (service entrance) to your house that can potentially supply 100a, 200a or 400a or whatever - if the house is empty and nothing is plugged in, then no amps are flowing.
Same thing with a portable generator; it might be able to supply 1600w, but if there is only a 100w of load plugged in, then it's only making 100w of power.
* Electricity is called "potential" for a reason. It doesn't actually exist until something causes it to flow. It's not like plumbing where there is water in the pipe all the time. With electricity, there is no electricity in the wire - until some load causes power to flow out from the supply. Until there is a load, then the supply is only a "potential".
