ReluctantTraveler
I've done a lot of reading on DRW vs. super singles, and most of what I come across is strongly held (often contradictory) opinions. I imagine a lot of the discussion here will also be opinion, but I'm trying to understand the pros/cons of both options.
I'm hoping to answer the question: is DRW really a problem?
There's also a second layer regarding F-350/3500 pickup DRWs vs. F-550/5500 chassis cab DRWs, as they run on different tires.
To summarize what I've read:
Some questions:
Apologies if this is treading tired, boring ground already covered elsewhere. I'm struggling to find clear answers, probably because so much of this is subjective.
- DRW...
- Provides better stability with a camper.
- Adds some protection in the event a tire blows out, as you have another one to fallback on while you get to the shoulder and pull over.
- Lots of commercial drivers take them on logging roads, service roads, etc. and the fear of getting a rock stuck is potential overblown.
- They might not be as good in the snow, but good tires can compensate.
- They suck in sand, because you can't really air them down.
- Super Singles...
- Might handle better in the snow (though some folks say they're worse).
- Are better in sand, because you can air them down more.
- No risk of rocks stuck between them (but might not matter).
- Less side-to-side stability with a camper on the bed, and if you get a blowout, that's the only tire so the rim might get wrecked.
- Heavier and more expensive.
- Maybe worse on highway/city roads because they're often military tires.
Some questions:
- Are DRW F-350/3500 trucks "different" from DRW F-550/5500's because they're not on steel reinforced 19.5 pizza cutters?
- Can you get smaller, non-military super singles? For example, Earth Cruiser's run Toyo 37's, but start their life as a DRW Isuzu NPR.
- Are their super single conversions that aren't $20k?
- Can you drive DRW trucks on the beach?
- Are DRW vehicles harder to fit in a parking spot?
