corax
. . . . And finally, my throttle is sticking at 1500 rpm's when I come to a stop from speed. This is a recurring problem that I think is the TPS. Will adjust and/or replace later this week.
when the thing is acting up and idling high try pushing the throttle body closed manually (under the hood) to see if your idle goes back to normal. On the 22RE's, it's fairly common for the throttle body dashpot to start sticking. This can also sometimes cause a TPS code to pop up since it prevents the throttle from closing all the way (ECU sees the "throttle closed" terminals never make contact and assumes a TPS problem, hence the code). I've always just removed the dashpot completely (2 phillips screws) with no ill effects, some people say you can clean and lube it to make it work properly
4crawler said:
LINK
Notes:
Dash Pot:
The GREEN CIRCLE shows the dash pot (DP) which is there to slow the closing of the throttle to prevent backfiring. It consists of the round air bellows, a spring loaded plunger, and the air vent line that attaches to the fitting at the base of the bellows. The vent line has a check valve in-line and an air filter to keep dirt out. The check valve lets air into the bellows then the throttle opens and extends the plunger. When the throttle closes, the stop screw contacts the plunger and pushes it in. The check valve closes to slow the air escaping the bellows and thus slow the closing of the throttle.
To troubleshoot the DP, make sure the air filter is clean and make sure the check valve is not clogged or stuck open. You should be able to blow air into the bottom easily (filling the bellows) but it should be hard to suck air out. Both the filter and valve can probably be cleaned with a mild solvent. Also, the plunger can stick. I find a shot of silicone spray applied to it periodically helps keep it moving freely. Lube it the push it in and out fully a few times to work the lubricant down into the plunger. And you can simpy back the adjuster screw all the way back to keep it from contacting the throttle linkage as a test. This way it is eliminated from affecting the throttle operation, in case you think it may be causing a problem.
To adjust the DP, I find setting the stop screw to depress the plunger about 1/2 of it's travel works well. If set too deep, you have more spring force to overcome and that can cause the throttle to not fully close. Too shallow and the DP can't really do it's job.
