Project Motodog
Started painting today:
Also changed the oil and cleaned the carbs:
And started putting it back together:
This is where i called it a day:
redthies
Renaissance Redneck
Looks fantastic! I'm thinking you will need some serious hearing protection when you drive that thing. Can't wait to see it in action!
So, i`m finally back working on the motodog. Now i need to fix some designing errors that i made. The first is to fabricate a new intermediate shaft, the one that sheared and second is to triangulate the secondary drive. Should be done pretty fast and then i can finish the track.
Just need some suggestions on the final drive ratio. At the moment i`m at about 1,5 to to motorcycle drivetrain. I think this is too fast, so what should i go with? 2,25? 3?
Anyone know what the transmission ratio is in those motorcycles? Especially in first?
Removed the drive axle first:
The sheared intermediate shaft:
Couldn`t get the bearing off so i drilled out the shaft and cooled it from the inside:
Want to reuse the sprocket flange so i hole sawed it off:
And hole sawed a new hub:
And welded it together:
Started machining the new intermediate shaft:
Bored out the sprocket:
And the flange for the other sprocket:
Then i preheated it:
And welded it in sequenzes:
Welded the sprocket flange first today:
Then i started modifying the drive axle. Funny that i got all those machines and have to use the hack saw:
Turned it down:
Bored out the new sprocket:
Turned a stub shaft:
And welded it:
dhuss
