Project Motodog
Ok, the secondary chain drive needed more triangulation:
Brought out the ole stick welder to tack it:
And welded it:
Pulled the carbs and cleaned them again today:
I think the fuel tank is rusty on the inside what makes the nozzles getting clocked, so i put a small filter in the fuel line:
It`s running, but not really smooth. Have to get into that in a while. :
Mounted the strut:
And put on the secondary chain. Have to redo the chain tensioner because it`s not lined up anymore:
Is there any interest in this? Posting for over a week without an answer implies that there is not much left...
This afternoon was a meeting from the german enginners forums and i really wanted to take the Motodog with me, so i started finishing the track this morning:
Cut two windows to reach the track tensioners:
Track on:
Ready to launch:
And like you can see on the video it worked like a charm. Really happy about that. Was even able to drive in my vanagon under it`s own power:
bdp1978
Its really cool, and well built, but umm... what is it?
Agreed, I just stumbled on this thread and think its awesome!!! Your work is top nothc as well, but what is this thing? Are you going to stand on a sled behind it in the snow or?????????
Well, no idea how to call it, i think it`s my invention... :smiley_drive:
Plan is to stand behind on skis and let me pull. But I`ll eventually buy a small 800lbs trailer to sit on to make it a complete vehicle...
Did some more testing today:
The Hägglund is on hold until this one is finished.
Did some more testing yesterday:
[video=youtube_share;u6TDZyRdVP]http://youtu.be/u6TDZyRdVP[/video]
Works great, but i need to get a thumb throttle like a atv soon.
Pretty easy answer, there is nothing like a high center of gravity. :smiley_drive:
Fixed up the chain tensioner. It was a plastic wheel and not in the middle:
Wanted to put on a steel wheel and weld a sprocket to it:
Because the sprocket was hardened when i welded the shaft to it i wasn`t able to bore it out. So i used a hole saw and cut it out:
Then i was able to bore it out:
Fit`s:
Unforunatel there was not enough room for the sprocket so i`ll try it with just the steel wheel for now. If it doesn`t work i`ll cut the tensioner mount off and reweld it:
java
I want to see it run in the snow! There are lots of videos of other Russian home made moto dogs, but most use little lawn mower type engines. I want to see yours rip!
dhuss
