Consider the safety thimble instead of a hook. My current line has it and I couldn't be happier.
Pete
I like the added safety of the thimble. Slide a shackle through it and it's secured to your anchor point, whether that be a tree strap or otherwise. The connection is solid and there is no chance of a hook slipping.
For snatch blocks, there are a number of good brands. The new ARB 9000 Snatch Block is a thing of beauty. (reminds me that I need to visit Jan to pick mine up!) Snatch blocks are heavy units and the 9000 is only about $10 more and half the weight.
Pete
Pete
Okay, I went with a Viking winch line with safety thimble through Sierra Expeditions. Thank you to all for the help. One other question I have is regarding replacing the old cable line. I just pulled it off and the drum is littered with metal shavings from the cable. Is there any special way I should clean/prepare the drum or should I just wipe it off as best I can and try to remove all the metal before spooling in the synthetic line? Thanks.
