Roaming Lost: x3 Locked 1990 Toyota HDJ81 (80 Series)
roaminglost
Got all my Redarc gauges wired. I freaking love these things. EGT/Boost, Water Temp/Oil Pressure. and Dual 12v battery.
I also was working on my portable battery box. got it all wired up for the most part.
roaminglost
I got my Stedi Surface 6 rock lights wired up. They are pretty slick, being RGB, and they have an app you can mess around with.
roaminglost
Ironman 4x4 really did an awesome job installing the new lift kit.
With this old truck, there's a bit of rust to get through; they had to drill and tap some stuff, but overall, no shortcuts were taken.
The kit I went with was the 4" RHD Foam cell pro kit they have on their site, but they added the control arms. My bushing was beat, so they also swapped the radius arm bushings for some new ones.
Overall I got 3" over whatever I had (Frankenstein suspension that it came with).
Before and After
roaminglost
These low-range gears are pretty awesome. I tested them out with the most rutted, steep spots I could find, and it just crawled up with the locker on.
Sumo transfer case low range 3.1:1
WonaWarrior
