Scott, in your experience what is the best way to "solve" the head gasket issue?
Pop the heads off, inspect/replace with OEM gaskets and bolts? Refill the coolant and be happy?
Is there any merit to looking at aftermarket parts? Are there any worth bothering with? Cometic? ARP?
If one was say casually shopping for a MY04 DII would it be prudent to do the engine reseal "because" once it was brought home? (assuming it hasn't already had a history in that regard)
Just thinking out loud... in the early part of the last decade there were lots of reports of "crap" chinese fasteners making their way into manufacturing plants. What are the odds the inconsistent torque to yield bolts are caused by this?
I don't know regarding Chinese fasteners but I think poor bolts is a likely contributor.
Cometic makes outstanding gaskets. I use them when I have engines rebuilt and blueprinted. The problem is you can't just throw them on as a service fix. They require a fine level of machine work on the block surface as well as the head in order to seal properly. I use factory gaskets with an extra layer of sealant around the oil pressure supply ring and the water jackets and use ARP head studs. This method requires re checking the torque after 500 miles or so. It adds extra expense but so far has been a very consistent fix. Aside from nice even torque with the studs you are relocating the clamping force to the top of the head and no longer asking the coarse aluminum block threads to bear the load. 4.0 litre engines have thin casting between the water jackets and the cylinder liner. When these blocks crack it is usually right along the edge of the head bolt threads between the liner and water jacket. This allows coolant to seep up and eventually penetrate the gasket. If you have a cylinder head off and you see a cylinder (usually 6 or 8) that appears to have a piston steam cleaned it probably is due to a crack. Using the studs helps relieve the stress on the thin casting.
A thor variant engine cannot "drop a liner" as the liners are pressed down onto a machined lip in the block. On a 3.9 or early 4.2 the liners could drop down and it was evident. It is possible for later engines to have liners shift following a crack in the block but this can be hard tell, the steam clean effect is a good indicator. 4.6 engines have thicker castings and resist cracking much better than the 4.0.
When Rover switched from GEMS to Bosch management the running temperature of the engines went up. It isn't uncommon for a D2 to run in the 200-210 degree range on a hot day. Not good. This is why if you have a catastrophic coolant loss or overheat, ie hose blowing, the block is probably toast. I have an intake manifold that is being modified to run a 180 degree thermostat in it allowing the relocated thermostat to be removed and dropping the running temperature. I have yet to try this myself but I am hopeful that with a retuned ECM will allow for safer running temps. I'll post pictures of this when ready to install.
Regarding shotgunning the repair. My D2 has 102k on it and I have yet to replace the head gaskets. This isn't common, but to answer your question don't fix it till its broke.
Once it starts leaking do it.
I hope this flows ok.
