Scrambler84s 1966 M416 trailer, towed by Big Red
Scrambler84
more parts getting the 2nd coat of black
2nd coat of black on the springs
primer and 1st coat of black on the axle
Scrambler84
Reinstalled the drawbar "V" and the pintle casting mount and pintle
Yellow Shocks on my trailer?
I don't think so
Finished reinstalling the Leaf Spring brackets and the landing gear leg. I had to cut down the landing gear leg top piece down to use the bottom whole for the pintle. It couldn't have been the original leg holder because it had to sets of holes for the latch pin. It now clears the pintle properly when the landing gear leg moves up to be stowed for towing. The OP had made a notch for the top piece to allow use of the top hole or it wouldn't have worked either.
DonBeasley
Really coming along and looks great. Nice pics!!! Are you doing a springover to get the tires to fit or moving the vendors?
Scrambler84
SoA for now, will help the fenders fit the tires I hope
checking out the trailer height
Seems a bit high but it should come down some when the tub is back on it.
tires are 31x10.5x15s from my 84 scrambler,trailer has about 2 inches of lift from the SOA, and maybe an inch from the new shackles for the springs
Kevin Braun
Mountain Biker
What shackles did you end up using?
Looks great! Did you have a special pressure setup or just hit it with what ya got?
Didn't toss those wheels I hope?...
Scrambler84
I used the same shackles another guy had used here http://www.expeditionportal.com/forum/threads/126686-ArmyGreens-M416/page3
Daystar KJ61001BK 0.5" Lift Greaseable Shackle
They worked great
I actually have 4 rims to were sand blast, primed and painted, the other 2 where on the trailer when I got it and tires on them are completely shot. I also have 2 brand new tubes from Summit Racing, was gonna get original tires to go with it but I had these to use for now.
Scrambler84
power washed then wire wheeled the bottom of the tub today
Hope to prime it tomorrow and paint it semi gloss black like the frame for now, might undercoat it too
Scrambler84
remounted / installed the brake handle after I cleaned it up and greased the bolt underneath the center of the trailer.
Scrambler84
Made brackets to allow brake to function after the spring over axle modification, they give shorter attachment points for the cable to be bolted to.
This piece you slip the adjustable cable hook through and bolt it to the L piece that is connected to the brake handle
Sanded down to paint. they will get 2 coats primer to coats black semi gloss just like the frame.
Scrambler84
Tested out the trailer this weekend, not sure about the Spring over Axle yet.
Doors off and ready to go wheeling at The Cove, Gore VA
Scrambler84
What do we think of making a fender that looks like this its not as tall as the stock fender but looks better IMO with the Spring over Axle setup I currently have for the trailer. It doesn't look like the fender is 5 miles above the wheel. It uses 4 of the 5 stock mounts and holes, might also extend it further down to cover more of the wheel?
ended up being 25 inches across the top, 13 inches wide and the downward sides are 11 inches long, has a 1 1/2 inch wide lip on the front like the stock fenders do.
side view
45 angle view
front view
comparison with stock fender
It covers the wheel with about 1/2 inch to spare allowing for wider wheels later if I go bigger.
Mark Harley
I like the shorter fenders.
get some black sunbrella canvas to cover the top.
Matching thr tub to the jeep? Matching Red would be awesome.
Scrambler84
Been a while for updates, but I have been back to work on the trailer
Okay started on the "roof rack" for the trailer yesterday, because this came on the truck Friday
set it up in the garage, he thinks its his new fort
one rail installed have to drill the holes in 2nd rail tonight, on inside lid there is a 5"x2.5" metal plate I cut from 1/16 steel scrap to keep the rack from pulling through the 3/4s" plywood, (I'll get a pic later). Rails will be centered on the trailer at about 15 inches either side of center
I installed the 2nd rail on Monday night and got the tent mounted up late
This shows the inside and the mounting plates I cut that are 5"x2.5"x1/16" steel, this shouldn't pull through with 5/8 bolts, JK control arm bolts actually
mounting up tent centering over the axle as best as I can to not increase the tongue weight
can still lift the cover to get things underneath even with the tent up as long as now one is in it.
Tuesday evening, tent with cover on
setup but found out the hard way will fold up with you in it, needs braces in the back.
with awning extended but bottom not zipped on
Made some temporary braces till I can buy and mount jacks or something
inside when set up
