Cole
Wheel thoughts?
Since a screw in the tire the other day (and a rusted out spare rim) I've been working on what to do with the tires. I only have 3 good ones and a mismatched 11 year old spare. All 226/60/16.
Option 1 is to keep the stock 16s and run a 215/70/16 BFG A/T. Basically the largest size known to fit without issues, cutting or CV angle issues. Requires a little work to lift the van about 2" but no biggy. The issue I have with this is that at the moment I'm going to leave the van 2wd with the autobox. The auto doesn't have a very low 1st gear and kinda stuggles off the line but does great at freeway speed. Larger heavier tires would make this worse.
Option 2, which is the most common route with these vans is to lower/leave stock, and run a larger wheel and more performance oriented tire to improve handling. Van would still work great for most camping off "dirt" roads.
Option 3 is a hybrid option of running a larger wheel for handling but also running the largest tire I can for ground clearance. The only issue is that there are very ew A/T tire options that fit in 17/18" wheel sizes.
Along those lines I snagged a set of S4 Avus wheels today for a song. A bit rashed but straight (17") Not sure if I will use them or just refinish them and sell them.
This is the 3rd set of these wheels I've owned with my S4 and S6. Very durable factory wheel! Also easy to refinish.
