Cole
Ever have one of those brilliant moments where you realize you're an idiot?
After having everything including the diodes tested in the alternator again this morning by the alternator shop something dawned one me about one of my tests.
My 20 year old test light was broken so I splurged the other day mid testing and bought a new one in a rush for $6 at the auto parts store. I used it to test and try to excite the alternator into action with no luck.
Anyone want to guess why it didn't work?
It dawned on me this morning that the new test light is probably an LED inside instead of an incandescent bulb and won't provide enough resistance to "excite" the alternator. Went home and made a new exciter wire bypass out of an old KLR650 license plate light( who needs those on a KLR anyway?) Well, this time it worked. Alternator started putting out 13.6v. Sill not the 14.4 I would like to see but it was a major step in the right direction.
The wire harness plastic cover from the alternator to the battery area has been taped up with electrical tape in the past. So obviously someone has been in there for some reason. Not sure what they did yet. I'm guessing some sort of bypass. I may even be connected to the 12v power outlet circuit I mentioned earlier. Which would explain why it doesn't work if this circuit is grounding somewhere. What I don't get yet is why the dash light works exactly like it should. Guess I will find out when I tear the harness apart to try to fix this right. I the mean time I may bypass it myself to a different circuit to make the van usable.
