Skinny's Frontier Build - Blanche
Skinny06
Pass through the roof with a strain relief and into a weatherpack 4 pin connector.
Each cargo/scene light is isolated and switchable on the roof as well as the main power switch.
The roof wiring isn't 100 percent tidied up yet, going to wait until the last sub harness is done before properly routing everything and getting rid of that hideous bundle.
3x Baja Designs Squadron Sports - One spot, center front. Two scene/cargo one mounted in the center of each side
2x Baja Designs Squadron Pro - One in each outside front position. I'm still going to have to play around with the lenses and aiming to see exactly how I want them oriented.
Skinny06
Got out over the holiday weekend to test out the new setup. Ran into a ton of locked gates so we didn't get any wheeling in, just some FS and logging roads. Did find a nice mountain top view for lunch and camped next to a river with some friends. Figured out a few needs/wants and a few things we don't need. Should be set relatively soon for our more extended trips.
Skinny06
Did a little modifying and re-configuring of my Precision Welding dual swing out rear bumper. Originally @eolivas built this swing out to hold rotopax and a hi-lift. With the setup of my truck evolving the hi-lift is now mounted on the side of my bed bars so this space was unused. In order to reclaim some space elsewhere, I figured this would be a handy spot to store all my recovery gear. So I picked up an 81mm mortar can to test fit and make sure it would all fit, and with a little organizing it does!
@TwinDuro and I chopped off the upper mount for the hi-lift, and cut off one of the edges of the lower mount.
Then fabricated a rear support, boxed the end and welded in some spacers to add some strength. Test fit was mint!
Skinny06
Then some VHT roll bar and chassis paint to match the rest of the bumper as closely as I care.
Final Product
I'll get one of the small locks for the ammo can and it'll be done-done.
This holds a 25 ft. winch extension line, a 10ft tree trunk protector, a 20ft snatch strap, the stupidly large 18k snatch block, and several soft shackles.
