Smittybilt Scout Trailer Reviews?
RichardPT
Richard
Thanks for the comments. Box on the side is actually a Jeep box that should go behind the back seats of a two door. Not too many of them left out there and is not cheap but I liked the shape of it with the slanted front. The drawback is it only fits on one side of the trailer but I keep my fuel on the other side anyway.
Trailer performed really good on the highway even at high speed but it freaked me out few times when it got really wobbly, I think because of side winds. Maybe it has something to do with independent wheels, it was not swaying just going up and down on opposite sides.
We just came back from riding Hell’s Revenge in the Jeep - what a blast ?. The little Jeep that could.
Etoimos
Thanks guys for starting this thread and keeping it going. I've been kicking around the idea of an offraod trailer for a couple years now (I want some thing small and trail ready and the wife would prefer something more glamperish... go figure). I initially saw the Scout and thought it looked cool, but the Smittybilt name made me move on without much time spent on it. This thread has revived my interest in it.
I'll be pulling a CJ tub trailer through Death Valley for a week (a loaner) and I also checked out one of the Boarder Land trails up in Denver last weekend. That thing was really nice, but for $25k it should be! I'll also be going to Expo West where my goal will be to checkout other trailers. But I must say, the modding you guys are doing makes me want to do it to!
Erling, I'm really interested in what trails you end up doing pulling you Scout since I'm here in CO as well.
Etoimos
Oh, have any of you thought about mounting your spare tire on top of the box, between it and the RTT? If you also add water tank(s) under the trailer, it should cancel out the top heaviness. I know it would still raise the center of gravity some, but not by much I would think.
Arctic Cat
I'm pulling my trailer with a 2001 Ford F250 with a Reading Box in the rear. Because of the box, I had a hard time finding a rack from it, at least no without paying a premium. So I repurposed the trailer crate and began making my own rack.29177299_10211101398916095_1777902434867927502_n.jpgcrate.jpgrack 1.jpgrack 2.jpg
View attachment 430656View attachment 430657
Finished my little pull out pantry and put side on stove drawer to turn it into just a drawer with lock on it. Also put a bungee net across front of pantry to keep stuff In it
Midnightsun -- In your pic i see your switch (power) panel. Id like to do something similar, can you describe how you did it? I am an electrical noob BTW so the more simple the better (small words )
Multi-Quote This Message
ebrabaek
My tow vehicle is a 2017 Ford Escape. I know that if the Escape will clear, the Smitty will as well. If you believe my 19 old daughter, I will soon have a JL ( as I work for our local Ford, Toyota and Jeep dealer) I am however not so sure. Regardless in the meantime I will not be doing too much crazy stuff with that being the case. If ya wanna see one, you are most welcome any time if you flow through Grand Junction. I just pillaged a Engel fridge...... My journey is complete.... Almost.. :)
ebrabaek
That is great to hear Richard. Hells is a respectable trail. Cheers to you and your fam Sir. :) :)
ebrabaek
I managed to pillage an Engel 40 qt marine keeeeeewler for $600 locally. It is a wee bit big, so I will need to fab another basket for the right side gen/fridge box on the smitty.
Hey all,
I ordered my trailer (should get it in 2 weeks) and id like to start getting the electrical purchased in advance. I have looked through the posts... can you help me with the supplies?
I am planning to have immediately - exterior lighting around the trailer, lighting run up to my tent, ability to charge the battery either by my generator or by solar. And maybe in the future water heater / pump (this will come later)
Here is what I think i need so far -
1. A switch, these seems to be the preferred type https://www.amazon.com/DCFlat-Water...rd_wg=yc6pk&psc=1&refRID=SW6PB6PBRF75MR0W44TH
2. A battery - i already have this one https://www.amazon.com/gp/product/B00IIZ0IS8/ref=oh_aui_detailpage_o06_s00?ie=UTF8&psc=1
3. What wire would you suggest?
5. The led lights (not sure which yet)
I know I am missing a lot, I dont have a lot of experience in this :)
Any help is appreciated!
mspenc45
Re-coating Bed Liner?
Has anyone done the bed liner over the existing chinacoat powder coat? Does it hold up, or must one remove the existing powder coat before re-coating with bed liner material. Whats the best bed liner coating for home application?
ebrabaek
I have just done the fenderwells. Mind you the frame of the trailer is zinc galvanized, and I find that the stock powder coat does not stick to that as well as the top sheet metal.
ebrabaek
Rather than fab up a whole new fridge pan, I found that with a little modification the stock pan would hold the Engel 40qt marine cooler. I did have to cut a bit off the front plate, as the length of the Engel is 25 inches.
Then I had to raise the bottom, and I did so with 4 corners of foam pads. Note the 4 corners filled with a precut piece of blue foam, and the front cut out.
Then another piece of foam in the corners was bonded on top of the lower piece, with 5 minute epoxy.
Then the Engel was sat down. I also did cut off the protruding 4 stainless bolts sticking out from the tray roller ( inside the basket).
Fits snugly in there....
mspenc45
Why Engel?
vertical.dan
