Smittybuilt Winch
adventureduo
Dave Druck [KI6LBB]
Just installed one on Yosh's TJ. We'll see how it works. Wasn't super happy with the quality of the controller, but everything else appears fine. Figured for how often the TJ gets used, it was a no brainer. The Landcruiser will stick to the WARN M12000.
SoCal_80
I have the 10k on my 80 series cruiser and it has been great. For the price, what i needed it for and a LIFETIME warranty through 4Wheel Parts.... Ya, it was a no brainer
bad80
Excellent winch! I have used mine (more than 25 times) for more than a year and is still great. It is slow but it gets the job done and costumer service is top notch, HIGHLY recommended. I'm getting the new 12K lb for my Land cruiser.
My friends have Warn M8000 and 9.5XP and they have already broken at least 2 times each. The warns usually over heat and the solenoids just burn out and the smitty is the one that have to finish the pull.
M
MuddyOval
Guest
In the article posted, they refer to it as possibly a re-badged MileMarker. Kinda true- as a Milemarker is a re-badged TMax. TMax makes many of the 'private brand' winches on the market and once you've seen a few they get easy to identify. MileMarker was the first widely marketed one, as the only winches actually made by MM were the hydraulic ones- the electric ones were all outsourced.
Although there are some differences in specs, most of these winches look the same- but you have to go beyond the looks. Some companies will spec their winches differently than others, although they will look the 'same' based on the casing. Some have bushings instead of bearings, some don't have gaskets to seal the gear case, some have higher HP than others. The control boxes are often sourced separately, so they can vary from excellent to garbage.
Shop carefully!
FWIW- I've been using TMax for about 6 years, both 11K and 12K models. I've worked them hard, very very hard at times and they just keep cranking along. I've actually had more warranty claims on Warn than Tmax, and dropped the Warn line. Only claim on Tmax was an add-on accessory wireless controller.
getlost4x4
i have a T-Max 9000 lbs. i've been using it for 2 years now.
i must say i am very impressed with it. the only problem i have is the wireless controller doesn't work. but i can live without it. other then that the winch has been great.
M
MuddyOval
Guest
The wireless controllers can be really picky. When you change the battery in the remote, you have to push the buttons a bunch of times to re-sync it. I've had a couple people with that problem, they just assume it doesn't work anymore. Try a battery and reset and it might come back to life.
getlost4x4
i had to replace the whole remote twice. when i pulled the chip it messed up the prong on the chip. i've pretty much decided i didn't care about the wireless control. i'll probably just rig up something so i can run the winch from inside the cab.
FlatlinesUp
this guy offers some nice switches/panels and are worth a look
Chris85xlt
i bought the Smittybilt XRC8000 combo pack which came with the synthetic rope and fairlead on sale for $400.
the fit and finish looks pretty good. one thing that bugged me was how difficult it was to unspool. it took too much effort to pull the rope out where my old Warn XD9000i unspooled nice and smooth. other then that im pretty happy with it
Donsfast
I have a Smitty XRC on my Jeep and it has been great, quick enough and never an issue. I have used several winches on car trailers for work and will use nothing but Harbor Freight #8000 winches for them, slow but great for the money. I have only ever had one winch break and that was a Warn 9000 on a trailer that got upset and threw up metal parts from deep within.
alexrex20
You can get the Warn 8000 for a faily good price, Quadratec seems to have a good price on them around $570 but they have had them as low as $550 on occasions. If your looking for used ebay and craigslist are great, I've picked up a 8k for $400 on ebay you just need to keep looking.
Warn M8000 is $530 at 4wheelparts.com, but is it worth the extra $210 over the Smittybilt? i thought it was, until my Warn's clutch lever seized and stopped going into neutral. (i guess that's better than not going into gear...)
CYi5
That is a good deal considering they were 700+ for like the last year it seems.
I'll be going with the Summit 9k though, it's a rebadged Tmax 9k. Summit has it on sale right now for $403.95.
I've heard the same things about XRC8's, reliable but slow.
mrchips
The problem with the rope/line being hard to pull out, take the planetary gears off the side and clean the factory grease out, some nasty goop. Repack and grease it with a good hi temp grease and it will spool out much better.
Houie
