So, I miss my LJ....
winkosmosis
There are a few serious issues with those wheels though. First, it's not uncommon to have that particular style not balance well. I don't know if they bend or warp or just come out of round but I've seen this issue of several XJ's. If you can't get them to balance and you think the tires are crappy. 10-1 its the wheels.
Another problem is they tend to either seize up and not come loose after they have been on for awhile or they will loosen up and fall off not long after you rotate them.
Keep a close eye out for those issues.
Why would they be any worse than other wheels?
BIGdaddy
Well, My Jeep was pressed into service as an impromptu shade device at our BBQ yesterday. We picked up a walmart large sized pool to keep the babies from overheating. It Worked a treat! Shade for the mommies, water for the babies and beers for the daddies.
Not a bad view! The end of the awning is very sturdy, and with some care, should last a long time.
BIGdaddy
Here's some closed pictures, showing the outer cover with its great stitching, heavy duty zippers and nice looking logo.
I'm planning on getting a MegaMule from BajaRack, maybe over the winter, but for now, I simply bent up some 1 in shelving support brackets that were already drilled with the hole required. Seems pretty strong, and does nicely right now...:)
Tons of space left for my canoe
BIGdaddy
Another month passed of steady daily driving on san diego's freeways...
-one bale of hay run over and killed, with no damage to XJ
-one minivan missed by the skin of my teeth with no damage to xj
-average gas mileage: 19.0 mpg
-Time offroad:( zero
Modifications performed:
-Recently added BCS cup holder
-Debadged body in preparation for home-spun paint job.
ExpoMike
Understand that. Not nearly enough offroad this year... well unless you count our trip last week to Hawaii. Had a 09 Wrangler Unlimited Rubicon!!! :wings:
Over 1100 miles of driving with about 150 of those offroad.
BIGdaddy
So far:
-Changed oil/filter
-dumped a bottle of injector cleaner
-changed serpentine belt
-changed fuel filter
-New Distributer cap
-New rotor
-New plug wires
-New Spark plugs
-New Radiator, with associated coolant flush
-trailer hitch and wire hookup
- CampingLab Awning
Planned
-front bull bar/winch mount
-safari snorkel
-rock sliders
-CB radio
-adj. lower control arms
-2.5-3" lift
-31"-32" tires
-JKS Quicker disconnects
-8.25 rearend
-new HD steering
-Tcase skid
-New Tint
-Rattlecan paintjob.
Just a tiny update...closing in on 170,000 miles with nary a hiccup. Installed a Tornado Air compressor into the rear area, that I was using for storage. Still have to run wiring to it, but I can already tell that I like this setup WAY better. I'll post pics soon.
Maximus Ram
So , I need them there nut-strips you bought Brian for my hitch also. Called the 'stealership" here. 30 bucks each. Think I'll either order from that link you have in here or maybe go and check out the pick-a-part around here.
With the strip, was it a pretty straight forward install ?
BIGdaddy
I ended up cutting my bumper mounts a bit to put them in, but it's because I intend on going with an aftermarket setup, and my bumper mount bolts were a bit seized. Otherwise, they basically slide right in and attach with the correct sized hardware.
the trimming can be done with a jigsaw or sawsall and basically just removes a bit of material from the bumper mount. These mounts can easily be removed, I'm sure, but I'm going to chuck them soon anyways when I get a backbone from detours.
Very easy, IMO, once I understood where they needed to get into the frame. about an hour to get the hitch installed.
BIGdaddy
cool. I already have an aftermarket bumper, so no trimming there.
yeah, you're golden then. The only slowdown was not being able to easily
remove the mount bolts. (and I got a bit impatient..hahhah!)
The website I posted is legit with very good email confirmation and speed of delivery. they came really well packed, too, so not even the remotest chance
of thread damage or bending.
-B
Maximus Ram
OK, Brian. I ordered them up, plus a few other stock steering items I needed, on your recommendation.
We'll see if it gets here as fast as yours....:sombrero:
Do you recall the size grade 8 bolts you bought ?
BIGdaddy
That's the same place I got my nutstrips. Fast shipping, and they actually have them in stock unlike some stores. The treads are M12 1.75 40mm long... or was it 1.25
I've learned in the past couple weeks that installing a hitch is harder than it sounds, at least when all your bolts are rusty.
these are the size...i totally forget the proper length.
Maximus Ram
Just my luck. Everything I ordered has to be dropped shipped from the mfg.
They had none of it in stock at their florida warehouse. So the wait begins.:costumed-smiley-007
Goldenbora
