I am only responding to comments made.
I will respect Gabe's wishes following this post, but I will first point out that your post is chock full of error.
1. Each wave not taken directly bow or stern on is an application of outside torque in three dimensions. Those tanken directly on the bow or stern - rare as hell - are a two dimensional application of outside torque. The twisting torque is everpresent.
2. Some portions of a hull are angled to provide ride comfort, but not all - and no one can predict every wave strike. For example chines are variously angled with an eye to smacking each wave full on to provide lift and to stop water from climbing the hull, to knock spray down.
3. The fiberglass skin applied to most wood boats is not structural and not intended to be structural or a stiffener just merely a waterproof skin, which is why expoxy resin is used. Though some boats do have structural glass, it is rarely in the skin. I'll refer you to West Epoxy's website on cold molded wood boat, trailer and other structure construction.
4. Boats are not inended to bounce off rocks, docks, navigation bouys or makers, just like trailers are not intended to bounce off trees, rocks or other vehicles, but boats hit their share of rocks, docks and aids to navigation, just like trailers hit their share of rocks and trees. In fact, smacking docks on landing is quite common, groundings are common and include mud, sand, rocks and coral reefs, striking aids to navigation less common. Off course, each grounding is also an outside application of toque.
5. Weight is a main concern of top end sportfishing builders as well, and that is why wood is the chosen material, along with it's superior stiffness, resistance to twist, superior strength and resistance to fatique. There are boats built of aluminum, fatique is an issue.
6. I won't bother with weight loading calculations, but I'll note that in a sportfish you can have two 3 ton engines 6.5' long and 4.5' wide sitting in the hull side by side a few feet apart. That and another 40 tons without hogging a hull. And that weight bearing capability is also relied upon each and every time a boat weighing from a few ton to maybe 50 tons comes down on a wave too. If you refuse to or can't recognize the immense force of water on a hull at speed, visualize the engines and all of the other equipment and gear accelerating with the hull as the boat drops, and then the hull absorbing all of the momentum from all of that weight as the hull stops as it hits the water, with any of the possibilities from an abrupt pounding to a reasonably soft entry, time and time and time again, hour after hour, year after year.
7. I couldn't find the torque numbers for a common diesel engine I had in mind, but 1650hp of Caterpillar diesel engine turning 2,300 rpm's sure produces a hell of a lot of toque. Multiply by two and the wood construction handles the torque without issue year over year for a couple of thousand hours a year in a typical wood built sportfish.
I could go on...
No one has to make wood strong, it is strong before man touches it. Want to see a ubiquitous example of wood's stength and absorbtion of outside torque as well as its resisance to fatique? Take a look out of a window toward your nearest ree next time the wind blows.
For more information, I'll again refer you and others to West Systems Expoxy's website, which might be found under Gudgeon Brothers.
JPK
