Coachgeo
background info:
1. No AC in 1950's home of only 640 sq feet (ok I lied...... on rare occasion use Window AC)
2. No Ac in Cab of truck
3. No AC in camper box (not yet purchased/built)
4. Income dictates..... mulitple devices that do the same thing is not in the budget, nor is it very logical. Examples:
.... AC in vehicle, another AC in camper........ Another AC in house etc.
.... Truck for camping, Another Truck for generic hauling etc.
.... Solar set up for house, another for camper etc.
.... power storage for house...... another for camper etc.
So here is concept considering
. AC unit- Portable Air Conditioner....
.... something like this one / DC with inverter type. 12-13,000 BTU seems biggist output out there. Too big for camper... not Big enough for cab.... trade off). Perfect size for a room or two in the small house.
........ Mount so it can be moved from one place to other between Cab, camper, house.
. Solar- Put as many watt cells as I can on top of fixed rack on over bed 8' wide and 16' long (camper box will be removable from bed). Maybe over cab too.
. Wind- Have wind power generator. when parked can be raised higher via pole and tie downs.
.... When down in travel mode can use moving air from transport to generate power**
........ yes.. know that this will cause drag and put a load on the vehicle engine......... AND SO WOULD PUTTING AC COMPRESSOR ON ENGINE. But typical truck AC won't allow for multi use (see #4 above).
. diesel Generator assist. (already own 5,000/6000 peak)
. Battery bank multi use as well (see #4). Maybe smaller bank AND Capacitors combination since really don't need more than 10hr? night time storage. Would be mostly buffer bank For AC during use and little lighting & computer and minimal? AC at night.
For Cab. Insulate the Shiat out of it. Cover windows when not in use so AC won't have to work so hard to bring temps up. Pre-cool cab hour or so before embarking. Vent to seats area direct. Pull air to be cooled from seat area? No intention to cool whole interior...... just space around seat(s). Curtin/divider off the area behind seats (LMTV cab). This area may be converted to sleeping loft anyway)
For Camper- Insulate shiat out of it. This will be a very small camper box compared to most. Only about 5' tall...... 6'-8' wide and 8'-12' long.
For house- Self explanatory. Park truck in back yard and plug into seperate wire circuit in house that powers on the portable AC (maybe computer too?)
Wiring oddity.... need external receptacle mounted on house, camper box and cab to swap power input from one to the other.
So......... plenty reasons why this would not work (or work well). How about ideas on how to make such an idea work as best as possible.
Look forward to your input.
