Skidmarkart
I know, I am an idiot for doing this, but I usually take my truck to one or the other of the cheap oil change spots around the corner from my house. Yes, I pay more, but it is easy and fast. I have always been warned not to go, and have never had any problems until now. This weekend I dropped the Monty off to get an oil change an got the call...
"The last guy who did this over torqued the bolt, the threads are stripped in the oil pan!"
Called the guys who did the last change and they swear they didn't over torque the bolt. I am sure you have heard this all before. In any case I am stuck with a oil pan bolt that will not tighten all the way.
I looked at the problem area. It screws in, feels like it is about to tighten, then suddenly looses it's grip when you start to torque it into place. I am really hoping that I can find a solution that doesn't involve the removal/replacement of the oil pan. I can tell just based on the amount of stuff in front of the pan this will be an expensive undertaking if I replace the pan (before I buy for parts). I have talked to a few mechanically inclined people about using a taper bolt to fix or rethread the hole... has anyone done this? I get the feeling that is a one-time-only, don't-******k-it-up kind of repair.
Any advice would be appreciated.
