Tell me why I should or shouldn't buy a 2011 Dodge Cummins- Decision Made
Rovertrader
Supporting Sponsor
certainly not to start the Ford/Dodge debate, but I have been 100% pleased with my '11 6.7 diesel, >20 mpg, tons of power and very comfortable. Hardest part was choosing between keeping the '07 PW, or the new Ford- and the Ford took the nod.
scrubber3
Not really here
Duramax+Allison=WIN
Just saying......
I like the cummings good enough, but I don't like what it's wrapped in.
If it was me, I'd buy used over new. To me it makes no sense to buy a new vehicle unless you have gobs of money and you don't mind paying out the wazzu. Though sometimes they make it hard to say no with some of their "deals".
toylandcruiser
Duramax+Allison=WIN
Just saying......
Chevy bodies are not any better than dodge.
Saiyan66
Ok let me confirm what was already stated regarding the 6.7 and foreign fuels. Yes the 6.7 with a DPF delete will run on any type of diesel fuel. It is recommended that an EGR and cat delete be done as well, but not required. The common rail injection system will have no trouble with the various fuels AS LONG AS THEY ARE PROPERLY FILTERED! If one wants to take one of these on international expeditions, an upgraded fuel filtering system is a must. Companies like FASS and BD diesel have excellent kits with large capacity filters that are easy to change out and can be purchased at any John Deere dealer.
On to the subject of the truck itself since we all know the Cummins is as reliable as the sun I wont even elaborate on that one. My experience with the rest of the truck (cab, transmission, frame, axles, brakes, etc.) has been with 5 different trucks of various years from 1990 to 2005. The one thing I can say without hesitation is this, the automatic trans has always been the weak link. This may not be the case any longer as I have no experience with the 68RFE trans. We have always owned manual transmissions and have had only one problem in over 1.5 million miles (cumulative). The cabs have improved immensely and starting in 03 were very well made. My dad's current 2005 has 180k on it with tons of offroad use and it doesnt have a squeak or rattle anywhere in it. My understanding is that the 2010+ is an even further improvement and from what I can tell on a test drive it is the most solid and comfortable so far. Dodge however decided to not offer the quad cab in their HD trucks as of 2010 so that kinda sucks. The frames have always been unbelievably strong and the loads that we put on our old 2002 work truck should be illegal (hasnt failed yet). Current axles are proven AAM components with ARB air lockers available for front and rear. Ball joints in the front are the one known weakness, but can be replaced with upgraded stuff when the time comes. Brakes are as good as any other truck out there, and with the true exhaust brake on the Cummins, last a very long time even with heavy towing. The downside is that Dodge brakes have always been know for high dust. This can ruin expensive wheels and just be a PITA to keep looking clean. I recommend EBC greenstuff pads to remedy this.
All said, I will be ordering a 2012 most likely tomorrow, so my decision has been made. I hope this didnt come across too biased as I am quick to admit that when shopping for a new HD truck, there isnt a bad one in the bunch. The 5.9 is always preferred, but I can swap out emissions stuff every 2 years without too much problem. For me that is really the only compromise I had to make when comparing the 5.9 to the 6.7. Hope that helps.
zb39
I have owned a 2011 Ram 4x4 crew cab DRW HO since May 2011. Gotta love 800ft lb...:Wow1: This is my 4th Dodge diesel and by far the best. Other than being set up to haul my Artic Fox 1150, it is stock. I am getting 13.2 mpg, but I don't run interstate and I am only 4 miles to work. The fit and finnish and ride are very nice. I love this truck and it has the room in it for the whole family. I got the Larimie Longhorn, go for it you won't be disapointed. I ordered the truck and I do own a business. Going thru their business link I got 10.5k off sticker, I was happy.:)
Francis
I have purchased a 2010 in March this year and like it real well. I was getting 17+MPG at first but now in the 15 to 16 average. I had the 8 foot box removed and a utility box installed. This increased my vehicle weight about 600lbs. Not sure this is the reason for the lower MPG.
Regcabguy
Oil eater.
just curious - with the emissions stuff deleted, can a 6.7 accept regular diesel...like the one you find in Central America or Africa...?
Shouldn't be an issue. I sat in a Mexican registered and built '08 2500. The Mexican registered trucks lack a diesel particulate filter because of the scarce availability of ULSD once you leave the border zone. It did have a cat and egr which aren't affected by LSD(fuel)
BCHauler
I believe I read somewhere that starting in 2012, the Ram trucks will be switching from DPF to urea, which is supposed to help the fuel economy numbers.
bfdiesel
That is not completely true. The DEF (Diesel Exhaust Fluid) system is in addition to the DPF. DEF helps with NOX and the DPF is for opacity (soot).
Starting with the 11 models the 3500 cab and chassis and bigger already have it. The tank is in a really bad spot too if you ask me. The Chevy is the same way the tank hangs down even with the bottom of and on the outside of the frame rail under the cab. The Ford tank seems to be much better protected.
ArmyTaco
The newer trucks have alot of nice features. My dad has one that is stock and it gets14-15mpg stock. Towing the 7500lb 5th wheel it gets 10-11mpg. If I was you get a g56 manual and delete the emmisions equipment. There has been many that achieved great MPG's by deleting and driving good. You get alot of nice features such as exhaust brake, nicer interior, lots of options to be had.
Now as far as being able to drive anywhere and run any type of fuel. Any CR Cummins is going to need a better fuel filtration system. I run a 5 micron Baldwin filter in the stock housing. I have a GDP 2 mic aux fuel filter between it and the injection pump. It has a Cat 2 mic filter on it. You have to be careful as one filter can say 2 mic and its really a 5 mic absolute. If you dont have good filtration you ruin your injectors. If I had the cash and it was 4k difference I would go new. Now that being said, I got my 07 5.9 G56 4wd CC with 62k miles for $29k. I couldnt afford the extra cash every month. I only average 14-15 with my truck. I have a tuner, intake, exhaust, 35's and the filter setup mentioned above. Diesel Truck Resource and Cummins Forum are great sites to check out and get any info you need. Good luck with your choice.
DT75FLH
Here is mine. completely stock with 285/70/17 tires and the 3.73 gears. It will avg 16 mpg at 80 mph driving from L.V. to San Diego.
(I got 16.5 going there and 15.5 coming back)
geographically you have to take into consideration that out west we drive over mountains and usually have higher speed limits. (a section of I15 in Utah has a 80 mph speed limit)
My buddy in Chicago gets a little better mileage on the highway due to 55-65 mph limits and flat lands. In fact he got over 500 miles on a tank driving from Chicago to Louisiana. only filled up once each way.
DT75FLH
FWIW...I prefer the TDR for dodge based resources. Alot of great info.
I think the new 68rfe trans is pretty stout. The is a thread on cumminsforum of a hot shot hauler who is plated for 33kGVW and running a dodge 3500 4x2 dually with the 3.73 rear end. He tows a 4 car trailer up and down from FL to NY. He has a running total of his major issues with the truck. The stock tranny went over 240k miles. and thats towing around 4-5k pounds over what it is "rated" for from the factory.
MuleShoer
redthies
Renaissance Redneck
Funny you should sate that. We were just kicking around the idea of changing the cab and shortining the bed.. Find a clean 2wd gaser for the parts.
I just don't know if I have the stamina to pull it off..to busy working on the my wifes land rover
I would head down to stamina-mart and pick some up! Clean 02-03 1500 2wd should be pretty cheap. I loved my '05 3500 quad shortbox. My wife wants a new Cummins truck and I keep saying sure, new '07!
Clemtiger84
