The AR-15
A worthy goal for AR15 shooters
In 2011 Carl Bernosky tied the National record for offhand shooting at the National Matches.
--The rifle was an AR15 based match rifle.
--Metallic (iron sights).
--Position was offhand/standing with no support.
--Range = 200 yards.
--Target = SR. The 10-ring is 7" diameter. The X-ring is 3" dia.
--His score was 200-15x. Out of 20 shots fired, 15 hit the X-ring, the other 5 were in the 10-ring.
Not too shabby for standing on his hind legs and using iron sights.
This is a photo of the actual target:
Wow.:bowdown: That is some shooting.
My little flame thrower:
80% Lower Receiver
RRA LPK
Magpul BAD Lever
Magpul Enhanced Trigger Guard
AR15 Bullet Button & Wrench
Exile Machine AR Pistol buffer tube and FDE foam
Ergo Enhanced Grip
PSA Upper Receiver
Blackhole Weaponry 10.5" SS Barrel
Rainier Arms Evolution Free Float 11" Handguard
Magpul Front and Rear MBUS
Kiess Master Blaster SS Linear Comp
PA Reddot
The paint job is more beat up now. I'm loving this little monster.
In CA-Compliant form
Out-of-state, throwing fits.
My previous featureless AR (now parted out) :(
JD Machine Lower Receiver
RRA LPK
Magpul BAD Lever
Magpul MIAD Grip
Magpul CTR Stock and Buffer kit
Custom featureless grip wrap
JD Machine Upper Receiver
Sabre Defense 14.5" Midlength Barrel
VLTOR CASV-M
ARMS #41B Silhouette Gas block and flip-up front BUIS
YHM Flip-up Rear BUIS
Surefire MB556K Muzzle Brake
This rifle shot like a dream. Little to no recoil or muzzle rise.
(pictured with the initial version of the AR Pistol with YHM Diamond Rifle Length handguard)
I decided to add a pistol to the mix.
ST lower
KAK buffer tube
Sig sb15 brace
BCM grip
LMT MK18 upper
KAC rail
ST BCG
BCM CH
512
Inforce WML
Etc...
I love having a pdw in pistol form...
Beside a 16" companion
Other side
R-
Ray
Here's the one that gets used and gets dirty. It's pretty simple really, just some iron sights and a light. A couple of spare batteries fit inside the pistol grip.
To be fair, the rifle he used is about as far from an M16/AR15 as it gets.
Incredible shooting no less, the amount of focus it takes to shoot that well off hand is eye tingling and mind numbing, I haven't cleaned the off hand yet... Come close though.
I am a HUGE fan of the AR platform. It is accurate, lightweight, versatile, durable, and reliable(if run well lubricated)
Here are some of mine
This ones not an AR but VERY fun none the less
Bernosky's rifle is an AR-15 in one of the 6mm calibers. Bernosky is a marksman, and I suspect the type of rifle and caliber makes little difference to him in offhand.
I made that post as a contrast to the AR-15 squirt guns and shooters whose objective seems to be turning the maximum amount of ammunition into noise and smoke in the minimum amount of time.....without hitting anything ;-)
Touché, and I'm Positive that he would hit with anything you put in his hands.
I'm assuming you're not new to the HP scene, I started shooting in 2008 with MCRD SD.
Just poking a little fun at the tacticool crowd.
I started HP in the 80's with a DCM Garand. Eventually upgraded to an M1A. I never could get comfortable with an AR-15 so I stayed with the M1A. I have to admit with 77 and 80 gr bullets, the AR-15 can shoot with the .30 calibers out to 600 yards. In the rapid fire stages the non-existent recoil is a major advantage over the .30 calibers.
I'm pretty much done with the "across the course" stuff and am easing into mid and long range prone. Bought a Winchester Model 70 match rifle in .30/06 for that. Yup - I'm a dinosaur.
This is my baby,
Rainer arms upper and lower
Young manufacturing BCG
Bravo company 16" barrel
Battle comp muzzle brake
ALG trigger group
Arms front sight, magpul rear
Spikes buffer tube kit
Ambi selector
All magpul furniture
Magpul BAD lever
Stream light weapons light
Sent from my SAMSUNG-SM-N900A using Tapatalk
I finally succumbed to the draw of an AR. Just before Newtown, I picked up a Colt 6920PD and did a little accessorizing with an Aimpoint Pro, Surefire, BCM and Spikes. Right after this I had a bad accident and didn't shoot for a year, I'm back to it now.
Not an ar but I wouldn't trade it for anything
This is a mini 14 that I built up over about a year. It's wearing a troy MCS stock, a mako recoil reduction stock, a custom muzzle brake from accuracy systems, all new springs, and a mo-rod Barrel stabilizer. Then a rattle can camo paint job. It's running a sightmark tactical red dot, with troy back up iron sights, a mag-pul foregrip, Harris bipod and a hogue grip. And I made up a Plano gun guard case to keep it out of sight.
I'm trying to conjure why anyone needs a muzzle brake and/or recoil reducing stock on a gas operated, semiautomatic, .223 caliber rifle....
nahuebsch
