spressomon
cruiseroutfit said:I'm far from unbiased, but I really have been satisfied with my Helton unit, its been installed for 3-4 years now without a hitch. The units themselves come in a handful of different configurations, some providing more hear than others, different fitting setups, etc. I'll be the first to say their pump system is a bit on the light duty end, though amazingly there are alot of them in service without problems (I have had a few come back dead though). For someone that will be using the shower on a regular basiw, I recommend the Helton exchanger (pick your flavor) and a different pump setup, easy to plumb, easy to mount, set it and forget it. For me it is one less thing to load and one less thing to forget
To the comment on "your motor will be idling for hours", well thats a bit deceptive. Do you plans ALL your vehicle mods around your entire group? Do you carry their spare parts? spare fuel? food? Thats like buying the 80 Qt Engel because your the only one that carries a fridge If your going to need that much hot water, easy, pre-heat a container of water. You can turn the pump on, drop the shower head back into your source and cycle the closed loop to preheat the entire bucket or container of water, takes a couple of minutes and your set.
My wife and I can shower twice each on 5 gallons of water, so for a 4-5 day trip we shower every other day. Thats a pretty conservative shower, get wet, soap up, quick rinse. When we are close to water, we get some nice leisure 100* showers . There are truthfully very few places (at least in my locals) that you can park within 10' of a good water source, so I've been packing a 5 gallon bucket in the trailer, easy to stow (fill it with other stuff) and you can ferry a bucket at a time from a nearby river or lake and take a nice leisure shower without using your fresh water. I've done the same using a Scepter can, unscrew the lid and sink it for a minute... I stopped doing this as I was worried about contaminating my cans (giardia, etc). I've even used the water out of my cooler for a quick rinse
I agree...the HH has been reliable and performs as advertised. The pump leaves a little to be desired IMO...but it is compact and relatively cheap.
Things got a bit more complex when I decided I had to make for a more efficient shower/water usage by upping the PSI with a larger pump to lower the flow rate (which has indeed provided more efficient use of water and getting a better spray)...that is too large to be mounted in my already cramped engine bay.
So now the pump is mounted in the nose box of my AT. I will be testing this new set-up over the next 5-days on a back country trip...what works great in the garage sometimes doesn't perform as well or as intended in the outback ;-). I suspect further refinement will be in order.
lowenbrau: Thanks for your info. I will check into them to see if they offer any advantages above and beyond my current setup.
