The next build my brother and I
Awesome build. I'm looking forward to the finished project. I'm in the early stages of my on build and struggling with deciding on an exterior sheathing and the building of the kitchen hatch.
One side of the trailer skinned.
This is the inside of the rear hatch with the light installed and the latch at the bottom.
We will be skinning the rest of the trailer this weekend.
Both sides and the top is skinned.
The window is cut out and fitted.
A shot of the passenger side completed.
You may be able to see the wires sticking out in the front and both sides, it's for the lights to be mounted. Next is the trim then painting the sides and top. Still working on the rear hatch mount and the shocks to raise the lid.
We are on schedule to hopefully be completed by the first of the year.
Sorry if I missed it but what you use to skin it? Is in glued or just rivits?
I used 24GA paint grip pretreated sheet metal, needed sheets that were 5' x 10' and paintable so this material fit the bill. To fasten the sheet to the frame I used stainless steel screws with adhesive under the sheets. I didn't want to uses rivets because each would need to be treated to prevent leaks.
What is the thickness of the sheets you used?
The rear kitchen door is mounted.
The trim is mounted around the edges. Side views with the lights installed.
The fan is installed in the top, ran a test of the fan and it works great. The fan is a three speed forward and three speed reverse, it moves a lot of air.
It's time to paint the trailer so here are the paint prep pictures. It will be orange on the sides, black in the front diamond plate and accessories and white on the top front and back. The orange will match my jeep.
The water fill and the shore power are taped off here.
This is the rear door with the license plate holder and the door latch taped off.
Jlbeats
