The Wanderers build
got a bit done
bumper is welded up
and on the truck for final fit
Interior (at least most of it) arrived today
dash I had recovered to give it a softer appearance.
and a new insert
not sure I'm thrilled with this part.... mostly because the glue on it is worthless
not sure this was the red I wanted but I really like it so it's all good
recovered headliner
put a lot more bolts in, can't tell except the battery is back in (which means the fender is on for good)
also need to add another elbow to the intake - so the coolant tank fits back in
Only that I don't believe you have mentioned it. Just throw a lawn chair in there and take a test run!
Just before paint was testing the turbo... it has a fuel leak that I need to fix before I get full jiggy on it but I've driven it some. Kind of fun with the tiny tires on it. There are seats in it, very beat up seats...
time to adhere the badge
so I've been fighting this for a minute getting the heated mirror wires through the tube through the door frame
but I found a solution, panduit reminants
first, though, you need to pull the grommet all the way through
it's large enough and stiff enough to push through but yet still make bends
same story v2
Onto finding out what parts I forgot to order..
Installing felts
after 2videos I still have no idea why these clips are here
installing the grill, the clips don't really hold so a bit of glue
the 'other' style...
set in place
bumper on
since the bumper's on there, might as well test fit the13k winch
I like the hoop but side riders?
hmm
yes
bumper is on mostly to give me a place to stand.... in that vein I'm not welding it on yet - because I'm clumsy and would trip on it
time to fix the leak
bottom most line....
fixed
reassembly
I've done so many of these I suppose it was my turn to not get them all completely tight. It was suggested a long extension and crow's foot ... nope.... ah well, if I wasn't hacking and sniffling I suppose this would have been a one evening task... alas, it wasn't
tbnd88
