Redline
Likes to Drive and Ride
No, my tire shop has not been using the super-duper adapter, just a good fit hub centric cone for balancing. I know this isn't the right way, but I really don't think balance was the problem with the Toyo MTs on the 4Runner.
All of my TRD wheels (and the stock wheels too) seem to balance fine using this 'normal' balancing method with all of the tires I have had mounted on these wheels. In the past 1.5-years the 4Runner has seen seven different sets of aftermarket tires pass under it (265/75 & 255/85) and I cant remember having a 'tire pull' problem with any of them except the Toyo 255/85R16. Though I thought my alignment was 'in-spec' I have learned that setting-up adjustable aftermarket A-arms can be tricky. I have a new alignment guy that I like very much. Even though the car may be 'in spec' per the machine that doesn't mean the previous tech got there using the optimum path. My new front-end guy is ‘the stuff'. I was having upper A-arm issues on the car during this time of tire pull. I thought the A-arms were set-up and aligned correctly but now I'm not certain.
Maybe the alignment was part of the tire pull problem, or maybe it wasn't. Again, there was/is no pulling with the Maxxis Bighorn's on the same wheels, balanced the same way by the same guys. But I'm willing to blame the A-Arms/Alignment until/if the Toyo MTs find their way back onto the 4Runner. For now the Toyos will stay on the F350, at least through hunting season, unless I don't get a cooling problem fixed, in which case the 4Runner may go hunting this year
hoser said:Redline,
When the shop balanced your Toyo tires on the TRD wheels, did they NOT use a Haweka Adapter on the balance machine?
There is a TSB from Toyota:
(SU002-96) Wheel Balance Adapter Kit
"9/2/1996 - All Toyota Models. To improve the accuracy of Dynamic Off–Car wheel balancing on all OEM Toyota five and six lug wheels, a precision wheel adapter kit must be used. For the greatest accuracy and repeatability, Toyota recommends using the Haweka adapter kit available through the Toyota Approved Dealer Equipment catalog. The kit consists of a precision ground centering cone for truck alloy wheels and a flange plate."
Some more info here too:
http://4runners.org/writeups/haweka/index.html
