Hi all,
Let me start by saying I am a total newbie when it comes to wiring/electrical. I am trying to wrap my head around the best way to charge a battery bank FAST. I'll keep this post short so as not to waste anyone's time.
My house battery system will have a 1020ah battery bank (4x255ah lifeline AGM batteries). I won't have any solar to begin with, or a generator, and will be relying solely on my truck's alternator for charging.
I want to upgrade to a 300 amp alternator, which will put out about 225 amps at idle I believe (XPS 300).
This is where I get lost. To me, how would I pull a dedicated amount of amps off of that alternator at all times to the house battery bank. Like if I wanted to hook up directly to the alternator and pull off 100 amps at all times. That would be 1200w (or 1440? assuming 14.4 volts?) theoretically I guess. Now I understand that power would be lost from the wire running from the truck to the back of the cab (camper), but I would use thick gauge wire for that.
Realistically, assuming this scenario, if I pulled 100 amps off the alternator, with a 6 foot run of wire through the cab/chassis to the camper (whatever gauge), how many amps could be pumped into the battery bank? Roughly how many, let's say, at 50% discharge, 70% discharge and 90% discharge? How can I learn this math?
Am I looking at this logically/correctly? And what would I need between the battery bank and the alternator to make this work to pull this off the alternator, a 100 amp charger?
Educate me please .... I am naïve.
