Very slow and mild 04 Tundra DC build!!
Greenyota
Suspension looks great are those OME 885 or 886s. We have basically the same set up and same topper I believe, but mines an 01' access cab. I'm running Bilstein 5100s front and rear and OME 886s up front.
Stone_Blue
Assuming you have the yakima tracks on top of your cap....Control towers and Landing pad 1's. I had direct bolted landing pads on my Tundra. I bought the 66" cross bars, but the 78" bars cost the same, and you can always trim em if you decide you want them shorter.
Thanx... :)
jonesw3
I finally got my sliders installed today.
Mo4130
Looking good. My only recommendation is to get rid of that damage multiplier, the brush guard. It does absolutely nothing aside from messing your bumper up even in the event of a minor love tap. Other than that looks great!! the roof rack and sliders look great!
jonesw3
I got in a minor fender bender 2 weeks ago and bent the brush guard so it's no longer on the truck. I will say that it did saved my plastic bumper cover from getting damaged. Plus it was a mount for my lights. I plan on fabbing up a prerunner style light bar soon.
jonesw3
Thanks. The sliders are Stubbs. I highly recommend them. You can't beat his customer service or quality of work. The camper shell came with Yakima tracks. So I just made a bracket that fit on the track.
jonesw3
I finally installed some much needed auxiliary reverse lights. Hopefully I can finish wiring them up this week.
jonesw3
Just a quick update. I spent all weekend doing maintenance work on the front end. I replaced the upper and lower ball joints, inner and outer tie rods, and removed the sway bar. It drives like a new truck now. Even without the sway bar on it.
AaronK
Those look like the same aux rear lights I've been planning and mounted the same way too. Do you like the lights and location so far?
Sent from my OnePlus One using Tapatalk.
RyanC-PNW
I've been looking at the rear lights options as well. Not a ton that I like for the Tundra. Do you have any photos of what they look like on? Curious to see what they look like when you're reversing through the cab and canopy.
I've been trying to come up with a way to inlay some lights into the rear bumper so they sit flush. Just not sure how to cut the chrome and still have it look good.
jonesw3
I still haven't wired the lights up yet. I plan on doing it this weekend. I will let you know.
jonesw3
I changed out the the front and rear diff fluid and the transfer case today. It was long over due. Of course once I finished I had to take it on a quick "test" run.
vertical.dan
