garrett
Supporting Sponsor
I can't see friction against the hawse getting heat high enough to melt the rope. The dang thing with cut like warm butter on an ehaust pipe thou. Heat is a problem for sure but friction induced heat when using it seems like a strech. Has this ever caused a problem or is it hypothetical?
I liked the weight reduction of the aluminum hawse. All the mods add up so it's nice to actually drop a few pounds every now and then.
Winching in synthetic rope for extended periods at angles that would induce heat are incorrect from a logistics point of view. There is no reason to have the rope at extreme angels on any kind of fairlead. If that is the case the operation has been set up incorrectly. The further away you get from a staight line pull, the "weaker" your recovery is. With the addition of snatch blocks at proper locations there should never been extended periods of time where the rope is producing heat at the fairlead. There are exceptions of course, but generally speaking.
But to assume that hawse fairleads are better is completely incorrect.
