The 5 gallon plastic can wasn't cutting it anymore. Too large to get small amounts of water. After reading a few posts on here a couple weeks back I decided to figure out a way to use one my corny kegs (homebrewer) since I already had the tubing and a cobra (party) tap. So I finally made it to ACE hardware today and I have a working setup.
The grey fitting is the standard in connection for corny kegs, and the other end is a 1/4" barb screwed into what the packaging called a tank valve. It is basically a tire valve stem inside brass fittings.
So I can now take a keg and pressurize it with my on board air to dispense water easily.
Break down if purchasing all the equipment.
$40 referb corny keg
$8 co2 side fitting (grey item in picture above)
$23 cobra tab setup (black fitting like co2 with hose and tap)
$2 hose
$6 brass fittings from ACE
I have a use for all of this except the $6 fittings since I homebrew, but it might be worthwhile for others..
$2 hose
