I am curious to see what a ARB'ed Pegged Rover diff costs..
If you think about it Mike, to do a Toy Swap (on a coiler, I leave Series to Jim)
But:
The rear is $575 for all the parts and machining (not including the Diff). A 4 pin Toyota diff can be had with 4.10 or 4.56 gears for $100 in usable condition if you look around. A Lot of guys Drop in a luchbox locker (not my choice but some guys don't have the $$$ for more) for $250 and they have strong locker Rear end for well under a grand.. The labor to actually convert the housing is "grind, drill and weld" Templates are provided so with reasonable care by the DIY guy everything lines up nicely. The front is a different story but only because you need to add CV joint's drive flanges bushings and a bit more machining. But for a Selectable (E Locker $1000) and the bits to do the conversion you are still under $2500. Consider that that allows you ratios that match Dana (see you can fit a Salisbury
) and the diff is that much stronger, no add the axles CV's you are using are all as strong as they can be either with a Coiler or a leafer it's the best bang for the buck.
I get off my soapbox now and let Jim finish :bike_rider:
Mag Chloride.. It's funny, years ago I had usually had to rush to finish a project on my truck to take it wheeling, paint or some protective coating on the steel was the last thing on my mind. It didn't matter because we didn't ever has rust problems here in Colorado.. Then they started using mag chloride, what used to be light discoloration of the unpainted steel in a few weeks is now full on salt bath corrosion complete with Iron Oxide dust.. Add to that the trees' on the sides of the roads are dying everywhere you go in the mountains tells me that we're in for some rusty cars and ugly forests come 2045 all because people are either unable to drive in inclement weather or aren't smart enough to purchase the proper tires. I grew up here and the most corrsive thing that was ever put on the roads was coal ash and gravel. I drop rear wheel drive cars and trucks with Snow tires I went slower and took my time. I didn't have to pay attention to a cell phone or palm pilot, There where 6 radio stations.. There where also many fewer cars on the road. Thta last bit may be the reason they need Mag Chloride.
