revor
Pegging or adding a Slipper Pad involves machining the Differential housing to accept an adjuster screw that is perpendicular to the crown wheel/ring gear at the point at which the pinion gear drives the ring gear. At the end of this (or these) adjuster screw is normally a Bronze pad that rides on the ring gear. The idea is that because when a large load is placed on the driveline the pinion actually deflects the ring gear causing failure. If the Slipper pad is in place it will help absorb some of this load. It is very a popular modification amongst Drag Racing types. Most Ford 9" and even mark Williams 11" Diff's will have a Slipper pad. Of course thos are extreem Hypoid diffs.
In many cases with a Rover diff with lower gears I have seen the pinion tooth actually break off of the pinion so in that case the pegging wouldn't do you much good. One problem with the rover diff that cannot be overcome by pegging. Due to the nature of it's being a spiral beval type gear the Pinion gear is quite tiny compared to Hypoid.
