What's new at Coyote RV/Phoenix Pop up?
My Phoenix Camper, Ski Area Parking Lot Edition, Part Two
Coyote RV is located in the Denver suburb of Commerce City, so after I took possession of the camper in January 2011, I went skiing at Keystone and Breckenridge with the idea of going back to see Robby at Coyote RV for any needed fixes or mods that I wanted.
In part one I wrote about factory installed extra insulation. I should also mention that while Robby doesn't supply inside storm windows, he did supply insulated snap-in-place covers for the window, door, and all roof vents. I will add rigid insulation between the window and soft cover and between the screen door and rear door.
I had the camper built on a 1-1/2" frame to raise it up to clear my 5th wheel hitch rails that are attached to the truck bed. In the spaces between the hitch rails and camper frame I have glued 1-1/2" rigid insulation, so combined with the factory installed insulation I now have 2-1/2" of insulation under most of the camper floor. I also covered a 1-1/2" thick piece of insulation with self stick shelving paper and glued it to the inside wall below the sofa.
My camper has a shower stall but no shower plumbing and no hot water tank/heater. I do not use the fresh water tank in winter so there is no chance of a frozen water system in winter. I have a porta-potti toilet and a portable shower called Hot Jugz which is essentially a 2 gallon pump up garden sprayer with a shower head and pressure release valve. I heat water in a kettle and pour it into the Hot Jugz, pump it up and I am ready to shower. The shower head puts out more water than a garden sprayer mist but less water than a standard shower head so I can shower using less than 2 gallons.
The amount of water coming out of the shower head is not enough volume to heat you up during a shower (but is more than enough to shower with). Instead I had Robby build a duct with an open/close grill from the furnace into the shower stall. This also turns the shower stall into a dry room for wet clothes and back up ski boot warmer if my electric boot warmers fail.
There is also a duct from the furnace that feeds the main cabin of the camper. It is located near the under the shower cabinet that houses the grey water holding tank. One of the later mods that I had Robby do was install a vent/grill near this furnace duct so I can direct warm air into the holding tank cabinet when needed.
Once I got into the mountains the grey water drain line started to freeze from the drain cap on the rear outside wall, up the drain line toward the tank. The simple solution was to have Robby install an on/off valve in the drain line about a foot in from the outside wall. This valve also works great in summer as it allows you to attach a drain hose without having the grey water gush out once the drain cap is removed.
I ordered the camper with 2 composite 20lb. propane tanks and a switch-over valve that switches tanks when one is empty. Robby for some reason couldn't supply the switch-over valve but it didn't matter because these composite tanks, made of fibre glass inside a frame, are not only very light weight but they are also "see thru". So before retiring for the night I just take a look at the fuel level in the tank in use and do a switch over if it looks like the propane won't last the night.
When I first looked at the furnace thermostat mounting position I thought that it was too close to the furnace but Robby said that it was in the standard position. I spent several nights at 0 degrees C/ -18 degrees F and it was warm in my sleeping bag and comfortable but not warm standing around in my underwear. At these cold outside temps the furnace would go on for about 15min. and stay off for 5 to 10 min. I wanted the furnace to stay on longer so I eventually moved it farther away from the furnace. It seemed to work better but I have yet to test it in the new position at really cold temps.
One of the standard features of the Phoenix camper is the fairly thick over hang with aerodynamic fibre glass front cap. This translates into slightly higher hard side walls and shorter height soft wall and higher 50" door when compared to some other pop-up campers. It also means under the bed storage which is a great place for extra winter clothing. The extra winter clothing under the bed also provides extra insulation under
the bed. The camper has narrow cabinets used for access to the camper tie downs that I will use for storing and extra sleeping bag on one side and extra winter jacket on the other side and these should help trap heat as well.
Some Other Problems and Fixes.
For combustion the furnace requires fresh air from both the outside vent and inside cabin air. Because of all the insulation, the small cabinet beside the furnace was not providing enough inside air to the furnace so a hole was cut in the cabinet door and a grill attached.
One unforeseen problem with the wide 2" side walls is that when the top is down and the soft fabric is folded in, the fittings on the end of the metal bar roof raising system pinch the fabric against the top of the wide wall. This chafing eventually caused a hole to wear though the fabric in a couple of spots. The 2" wide wall is essentially a 1" inner wood frame wall attached to an aluminum framed 1" outer wall, so I have chiselled down about 3/4" by 1-1/2" on the inside wall to alleviate the problem and it seems to have worked. The solution for future builds of similar design would be to have the top of the inner 1" wall to be about 1" lower than the outer wall.
Well that is about all I can think of to write about right now. I hope this helps give ideas to others who may be planning some cold winter camping.
Finally something new!
Wow Dano, Great information about your custom Phoenix!
Something's going on up there in CANADA.... lots of calls, e-mails, and orders. It's a wonderful place, and I can't wait to go back myself!
So, I haven't posted anything new from the factory in quite a while. Sorry about that, we've just been burried in the shop... work work work !!!
You wouldn't know it from my usual postings, but here is our most often requested truck/camper combinations. Shot bed full size truck, and camper with restroom/shower.
These two units were installed in the last few weeks. One, as you can see has the nice features of being flush to the tail lights, and has the extra long cab over. The other is longer, for extra inside space, so it has the tail light skirt option. It all just depends on what you want!
Don't oder this option!
Ok everyone.... I am tired.... This last couple of weeks kicked by butt!
All because of this.
This is called a "full height door option" and I DO NOT RECOMMEND THIS OPTION.
It looks kinda cute. Some companies have even built their whole sales pitch on the fact that they offer this "feature" on their pop up campers.... I've seen and built many versions of the "full height folding door" and there is no way to make it as good as a normal door!.... Gimmick, period.
Once in a while, people come to me and they say "If this thing just had a full size door, I would sure buy one." I always say "sure we can build that for you if that's what you really want, but here's why our regular door is better.
1. The WHOLE camper is stronger, so strong in fact that we offer an off road structure warranty with the standard door.
2. The standard door always closes nice and easy, and the full height door is always a hastle.
3. The standard door is always pretty weather resistant,and the full height door is always questionable in bad weather. The regular door is really not uncomfortable to enter and exit the camper through, since you naturally lean forward while climbing anyway, so your head slips into the camper before your feet carry you upward onto the camper floor.
4. A standard door will be pretty much maintainance free for its lifetime, and when it does finally die you can order a new one over the phone and install it easily yourself when it arrives on the UPS truck. The full height door is made up of many custom parts, no standard parts, and will need to be worked on regularly to keep working. If it ever fully breaks down, it will need to be re built by someone like me who will have to charge you for many many hours of custom labor, currently $100 per hour.
So, a "full height door" is a cute sounding idea on paper, but no matter how you try to build this thing, it's a BAD IDEA.
That being said, this particular customer ordered the full height door option anyway. His complaint about the other brands, who offer a fullheight door is that the campers themselves don't have the features and quality he wants, and some are built so you can't even open the back door when the camper's top is down. I think that is rediculous because you could NEVER stop on the side of the road, jump inside, and get something out of the frige or grab something from storage, or anything. You couldn't even lay on the lower bed in a rest area without raising the roof and setting up the "full height door."
So we built this one so you CAN open the door when the top is down. I think we did a pretty quality job on this one, but it really killed a couple of weeks in the shop.
As a whole, this unit turned out pretty nice though, I think. I like the convertable porta potti room/closet idea he had. I also like the upholstery material his wife picked out, very rich look.
Thank you DanoT, I'm very interested to read your posts. So, are you happy overall with the way the insulation package is performing and also the size of the furnace provided?
Runt
, good to hear; hope it works out for you. I’d love to read a report after a year or so of bush use you are planning.
Thanks guys!
Yes, I am very happy with the insulation package performance. The furnace is, I think, 18,000 btu and is quite adequate, but the fan does draw a fair amount of power so I would normally start my generator after skiing, switch to electric 900 watt heater and have the furnace turned off so the converter can charge the battery without the furnace fan drawing it down. When I go to bed I turn off the generator and switch to the propane furnace and keep the furnace on low during the day so my dog stays comfortable while I am out skiing. Droping the top during the day really conserves heat.
I'm pretty sure you would need to take the canoe off the roof to raise the roof. I know I would with my 8'6" Phoenix on a full sized pickup.
Maybe you could add gas assist springs to lift the roof similar to what some folks with ATC/FWCs do to lift a canoe.
Cari, I agree with you 100% about the structural issues on that full height door. The lack of rigidity is one of the many complaints I have with my Bronco 800. The flex in the rear section is brutal when there isn't anything connecting the two sides together. Also, depending how level you are parked, the door isn't always smooth to open and close. However, it sure is nice to have a full size door to walk through. I guess the shorter door is one thing I'll have to get used to after I convince the wife that we need to order that new camper I've discussing with you. ;)
Thanks for the insight. I've wanted a pop top since 1st reading the Turtle expo stuff but don't have any real world experience with them. I've seen scads of pics of them with canoes ect on the roof I was under the impression most would lift loaded. Not a deal breaker if it won't.
Well how strong are you? ;) Only half kidding, most of these use your human power to lift the roof, any weight you add you have to lift. I'm only familiar with the FWC/ATC style lift but it takes moderate brief effort to lift. Guys are adding gas springs of various weights based on what they carry to help out. I think around 30lb springs makes for an easy unloaded roof lift and some folks find lifting a canoe easy enough with heavier ones 60-100lb springs. However those same heavier springs will make it hard to close when unloaded.
I'd imagine the same stuff could be applied to a phoenix rig even though it lifts side/side rather than front/back.
Push button lift, good to 1,000 lbs!
Ok, I hate to cut in on a conversation, but I think that I can offer a solution for your questions.
We now have a wonderful push button electric 12v lift that can easily lift 1,000 lbs. It is pretty simple, low maintenance, quiet, and dependable. Not cheap, but it's pretty nice though.
We have built these for disabled campers, and for folks that really want to leave stowage on top while still lifting the roof.
Here's the video... http://www.youtube.com/watch?v=F4kHg5DKtyM
Runt
, good to hear; hope it works out for you. I'd love to read a report after a year or so of bush use you are planning.
Thanks guys!
Hey Klahanie
I will be keeping a very good record of how it holds up and the abuse I put it through. Rob encouraged me to do so and post my experiences. He is very, very confident in his product.
How dare you reign in your own thread! :)
Electric lifts work as well but since soft sided campers allow an uneven lift I'd personally be far more inclined towards gas shocks (cheap & effective). But as always options are great for whatever someone wants.
So, I've looked through this several times and don't find any examples of overhead cabinets. Are they even possible with your unique lift system?
I thought about adding overhead cabinets to my Phoenix but they would have to be mounted to the ceiling and just mean extra weight to lift up when raising the roof.
As far as the electric power roof, it is very expensive and very, very slow.
rocksandtrails
