thats clearly a bad place there.
when you kick it with your shin walking by it you will agree
also the front of the bumper is a place that will contact things off road and the main beam of highilifts are very ductile and bend easily making them bind during use.
you have the lifting hook facing down as well reducing approach angle and further exposing the jack to damage.
Sorry but that is a great example of how not to mount a High-lift.
Hey but dont fret...thats the stamped steel version and they dont last very long anyways![]()
Your "Cheap high lift" will lift just fine, i doubt your disco weighs 7k on each corner.
Your problem is "Lift points" I recommend http://www.hi-lift.com/accessories/lift-mate.html If you plan on using the jack for tire changes.High lifts can be brutal on the point where it comes into contact with your vehicle.
As for mounting it on your bumper, It will be fine if you just remember its there.
If you bump into it, it WILL bend.If you get stuck in the mud you may have to go digging for it(depends on how deep).
I also recommend if possible using a bottle jack if the conditions are right.
There was one time i had to use my high lift to get my rig up high enough to get my bottle jack under the axle:victory:
And as far as being a poser.......I think we all get a kick out of people looking at all the crap we bolt to our rigs.When i put something on or in my rig i do think "How will this look".
My high lift is kept inside the truck, strapped down right in front of the rear door. It's out of the elements, farthest away from the occupants, and easy to get to if needed. I leave the thing alone unless i realllllyyy do need it too... damn things get scary!
it's tied down lying flat on the floor. It would have to come undone, and then fly over the top of the gear in order to hit anyone up front. Plus when I need it all I have to do is open the rear door and there it is.
