Which axle upgrade route to take
James86004
Alaska Mike said:
Just be very critical when looking at the axle, if for nothing more than to get the price down.
By the way- do the brakes cross over, or is that another expense?
According to my Series IIA parts manual, they are the same.
The parts manual also says the Salisbury was standard on the very last of the IIA 109s.
revor
This is correct, every thing from the axle flange is the same...
Now you need so Series three front brakes to go up front! 3 inchers!!
You do have power assisted brakes right?
Careful James! I tend to talk a lot of people into a lot of stuff!!! In the end they're usually happy though:)
James86004
It is a 6 cylinder, so it has the big drum brakes. The PO also upgraded to an SIII dual circuit vacuum assisted master cylinder.
Alaska Mike
ExPo Moderator/Eye Candy
If you can pull it off cheaply, I would jump on the deal. I don't know what kind of shape your bearings are in, but you might consider swapping them while you're in there. It would add $100 to the price, but I'm anal like that on big projects. At the very least, you might want to replace the hub seals to save your brake pads. When you said the pinion was missing, I assumed the pinion gear- replacing that would require a setup. Just swapping bearings and some seals shouldn't be an issue if there isn't too much water in the housing. I'm hoping for the best for you, although I'm a bit envious.
Just think- with the money you save you can get disc brakes!!!:clapsmile
Alaska Mike
What happened to keeping the Dormobile original?:smileeek:
It probably goes with the bolt-on crossmember.
James86004
Nothing. It would be nice to have coils springs, but not on this Dormobile.
