Winch bumper
CreeperSleeper
Looking for bigger rocks.
Step Six:
Now that the center section is adjusted and bolted up tight, you need to mark where to drill for the cross bolts. This bumper is designed to have adjustment every way possible, so use that to your advantage. You will notice the bolt holes in the bracket are slotted. You may want to make your mark in the middle of that slot to give you more adjustment if needed. ***Note: People with body lift brackets have a lot less adjustment! Make sure that you mark the INSIDE of the frame. I don't have any good pictures of this, but it will be obvious once you see it.*** Once you have marked where the hole needs to be, it's time to take everything back off of your truck and start drilling. To make this easier on yourself, make sure to use sharp drill bits. You will also want to drill a small pilot hole first, so the big bit doesn't walk on you. Last word of advice, make triple sure that the drill is level and plumb before you start drilling and keep an eye on it throughout the drilling process.
Step Seven:
Repeat steps Three through Five. After that, slide the two top cross bolts through the brackets and the holes you just drilled (bolt, washer, bracket/frame, washer, nut). At this point, I would leave all of the bolts holding the bracket onto the frame a little loose. Chances are you are going to adjust the fit a little bit once the wings are on.
Step Eight:
It is time to bolt on the wings. You will notice that the wings have holes cut in them to slide over the black bolts holding the center section onto the brackets. This is very helpful, especially if you are going this by yourself! Now bolt the wing up to the plate/hoop/brush guard using the shorter stainless steel allen bolt, two washers, and a nut. If you have the full brush guard, you would use the same method on the outside mounting plates as well.
Step Nine:
Now it is time to put the bumper caps on. There is a left and a right, so pay attention! Once they are on, you can slide the bottom bolt that goes through the frame in the same way you did the top ones. Then you will use the six longer stainless steal allen bolts to attach the cap on the front. You will also use two washers and a nut for each of these.
CreeperSleeper
Step Ten:
Final adjustment. You may find that you want to add or remove shims, or slide the bumper around a little bit. Now is the time to do that. This bumper is designed to fit up to the vehicle tightly, but you have a lot of adjustment to put it how you want it. I know some people are worried about the bumper flexing into the body, so this will help you to put the bumper as close as you feel comfortable. Here are some examples of fitment and some more pics of this bumper in various configurations.
CreeperSleeper
I was able to pick up my bumper from my buddy, Nickko, at Zollwerks in Hillsboro. *He sandblasted and powder coated the bumper in Cardnal 20% gloss powder. *I got it home and TonsOFun helped me wire in the LEDs and get it installed. *I am so happy with how it turned out!
The LED's are wired to my factory fog light wiring. I just used a multi-meter to figure out which wire was positive and which was negative, cut the OEM connector off and wired in a Delphi connector for the LEDs. I am also planning on running an LED bar between the stinger, but that may be a while... I really need to focus on my 40!
Benc
A few random pics of the LC bull bar and different customers rigs. Also some pics of a customers bumper with custom two tone powder coat, pearl white wings and charcoal gray center. This will be going on a peal white lx470. ImageUploadedByTapatalk1433648402.950251.jpg
ImageUploadedByTapatalk1433648477.519565.jpgImageUploadedByTapatalk1433648497.848512.jpgImageUploadedByTapatalk1433648517.370396.jpgImageUploadedByTapatalk1433648540.797817.jpgImageUploadedByTapatalk1433648564.309517.jpgImageUploadedByTapatalk1433648587.814887.jpg
sgiandubh
Mine just arrived!
DIY kit came in middle of last week. Just need to clear some garage space to dig in. Thanks for the detailed directions and images. That will be a big help with the assembly.
Benc
Cool, let me know if you have any questions. The caps are probably the hardest part to the kit. Give me a call and I can give you some tips. Pm me if you need my number.
Benc
Hi guys, been a while since I've updated the thread here. Most of the action has been over on ih8mud.
I finished the first batch of 30 a few weeks ago and am now working on the second batch. I'm keeping this batch to 10 and currently have 6 orders so there are 4 spots left. Let me know if anyone is interested. Here are a few current pics. ImageUploadedByTapatalk1439947309.935961.jpgImageUploadedByTapatalk1439947344.390919.jpgImageUploadedByTapatalk1439947385.667274.jpgImageUploadedByTapatalk1439947416.459495.jpgImageUploadedByTapatalk1439947444.169781.jpg
tdferrero
Reviving an old thread. Are you still making these bumpers?
I finished the first batch of 30 a few weeks ago and am now working on the second batch. I'm keeping this batch to 10 and currently have 6 orders so there are 4 spots left. Let me know if anyone is interested. Here are a few current pics. View attachment 300077View attachment 300078View attachment 300079View attachment 300080View attachment 300081
WonaWarrior
