Shachagra- Family of 5 traveles Europe and Turkey, International 7500
Saiyan66
I absolutely love that truck of yours. Excellent job building everything. However wouldn't it have been easier to find a local hotel, chain it to the truck and just drag it down the street behind you? LOL.
MultiSmog
1. The truck doesn't have a generator, but I reserved a space for it if the solar just wasn't cutting it, but it did fine. The truck has a 320A alternator so if the sun wasn't enough the truck provided nearly the same juice as a 4K generator. We had 2100AH of lifeline batteries, that was a luxury, I could have gotten by with 1/2 that but we would have really drained the batteries at times, which they don't like despite being deep cycle batteries.
2. Toilet. 5 people make lots of waste and I wanted to be able to dump at about the same interval as I took on water, about ten days. We have a 40 gal grey water tank and a 40 gallon black water tank. In France, Germany and Italy the highway rest stops have dump stations. We used toilets a lot, if we could park near a toilet I have a 20 foot pumpout hose with a ball valve at the end that I could drop in the toilet, otherwise I used two 5 gallon buckets and made 3-4 trips. Not a job I loved.
3. Propane would have been fine, it was easy to find everywhere, but I wasn't sure how available it would be and the single fuel, diesel, was great for peace of mind. I love the webasco. It takes a bit to heat up, but works well. It is very expensive and if you break the ceramic top as we did, it was $800 to fix! We have an installed microwave and a toaster oven that we kept in a cabinet
4. I installed a blower fan for the dickinson diesel heater that worked so well we could have not used the radiant heat, but it was nice to take the edge off by heating the water tanks. The system was super simple. The boiler would heat the stainless steel water tank- there was an extra coil in the hot water tank that I would circulate water from the bath through- after it ran through coils in the main water tank. Heating the bath would also heat the water tanks, to a lesser degree, and thus the entire cabin. When I wanted to use the bath without heating the cabin I closed off the coils in the water tank. I should made a drawing, its actually very simple, completely manual and worked well. The reason for heating the water tank was that it would absorb lots of heat quickly and then release it slowly over a long period of time with nothing running.
I'll try and dig up some pictures.
Hola Doug:
Thank you for thaking the time to answer my questions.
I am very interested in your experience about waste management and your heating/plumbing system.
Did you any special installation to be able to dump the waste tanks into 5 gallons buckets?
With your current experience, Would you rather use a cassete toilet and keep several (2-3) spare casettes?
Would you be able to share both your heating/plumbing design as well as your ideal waste management system?
Thanks again for sharing, that is exactly what makes this forum so great.
Saludos
Roberto Espinoza
shachagra
Hola Doug:
The holding tank is a complete unit http://www.dometic.com/56932382-cbdc-4d20-8b6d-f854057dcfaf.fodoc Designed for a boat to be pumped out , not drained. If I couldn't get the hose- which is much smaller than a standard RV sewage hose, 1.5" to a dump, toilet or in some parts of the world, a really thick stand of bushes, I pumped it into the 5 gallon buckets. I would use a cassette if I could have used a gravity toilet- but the sewage needed to be pumped 6 feet from the toilet. You only see cassette toilets in europe. I'll make some drawings of the heating system. The key to it was the isotherm water heater with multiple heating coils. http://http://www.indelwebastomarine.com/home/us/html/7957.html I have the 75- 20 gallons. I'll scan some sketches.
shachagra
That chassis just might be able to do it, but it would have attracted even more attention-- which is hard to do.
shachagra
The berths really are a clever design. I've been trying to figure out ways to efficiently get something similar for my three kids and so far this is the best I've come up (see attached pictures). This will fit in the space most RV's use for a rear queen bed - about 8X8 feet. It's two "rooms" - one on the right for the two boys and one on the left for the daughter. We're considering possibly getting a toyhauler, building something like this in the back, with leftover space reserved for a small garage. Just one option we're considering.
Anyway, thanks for more pictures and info Doug! A few more questions for you since you seem to enjoy the interrogation! :)
You mentioned a shower - from the videos and website I had assumed there was only the bath. Is the shower in the bath and did you use recycled/filtered water for that as well?
With the Dickenson at one end of the trailer, how cold did the cabover get during the winter in Scotland? I assume that's where the radiant helped a lot. How did you make the loop in the tanks to heat the water? Is it an open or closed loop system?
What did you do for cooling in the summer? I don't see an A/C, nor any powered fans or vents. Were the kid's rooms ventilated?
I assume while driving the kids were riding in the booth in the back (it shows that on one of the videos). Are there seatbelts there or is the rig big enough to not need them? I imagine it got pretty bouncy up there!
How did the Vespa work out? I understand from the article that you got rid of the bikes at some point. Was the vespa mainly for errands and such?
The below-deck staterooms are a very clever idea, but I guess one compromise of that design is that you give up the storage that most rig use that space for. Did you feel you had enough storage and where was it located?
So if I understand correctly, the cab isn't mechanically attached to the camper? Did you have any issues with frame flex going over uneven terrain?
Thanks again Doug!
I love that bed arrangement, I had to break out the Legos and see how it fit together. very efficient use of space. We were looking at modifying a toy hauler originally, but they didn't seem to be able to haul much extra weight, the chassis was always at the limit and with the extra weight of water and batteries, we would have been too heavy- so we moved up to the medium duty truck chassis. It works great that the beds form two room, one for boys, one for a girl. I really like the design. I also have to admit I am jealous of everyones abilities with CAD programs. I really need to put some time in there.
Questions
1. Shower- the shower is the small room that the tub is in. It is heavily epoxied (4 layers) to make the entire room one waterproof shell. We didn't recycle shower water. The water heater is just below the shower floor so there wasn't much loss of water waiting for the shower to get hot. It is just a copy of a Japanese bathroom, they clean themselves in the shower area and then just soak after they are clean.
2. The Dickinson has a blower fan that runs through the cieling into the main cabin area but we never needed it. The overcab was better insulated than the rest, (3") due to the structure and it would stay warm on the coldest night just by body heat.
3. We have an A/C in the back just under the dickinson fireplace. You can see the 3 vents for it from the outside below the rear windows. It is just a household A/C with an extra blower to keep the coils cool. Never once used it in Europe or Asia, but ran it continually here in Fla before we moved back into our house. Every bed has a porthole and a fan. Fans work very well for keeping you cool at night.
4. No seat belts, and I'm pretty sure that's legal. Hopefully the lawyers won't tell me I'm in trouble. The ride is rough, so the family tells me, its great up front.
5. The Vespa was great, we used it all the time for running errands or doing some individual exploring when we were staying at one spot for a while. The bikes were just something to worry about. We actually kept two bikes stored inside, we sent the tandem back home.
6. We had more storage space than we needed and as always we filled it full. We spent 8 hours unloading the truck when we moved back into the house. The area where the Vespa was hoisted held lots of storage, as did a large closet just inside the cabin door.
7. No issues with flex- the cab and cabin were very tight together, there wasn't much room for flex.
Entropy
Doug,
That was done with Google Sketchup, which is very easy to use. I made that sleeping configuration after watching the first 5 Google tutorial videos, which took about an hour with me following along with the software. It was about another 4 hours of messing around after that to get to what you see there. I was surprised how easy it is to use and the tutorials are very good.
I know what you mean about the lego's. That design was from one my wife originally put on paper after a lot us experimenting with Legos and blocks. We have a few other configurations, but that one is the best we've come up with so far - at least for a single, square space.
Since we're still a few years away we don't really know yet what vehicle we'll use. Toyhauler's are getting harder to come buy - not too many made anymore. We're considering everything ranging from a total build on a MDT chassis to just buying something and dealing with the compromises.
Ha! It's good to be the driver!
Thanks for answering more questions! Have a good Thanksgiving!
-Andy
PS: Ah, you're in Jacksonville! We're actually moving down to Melbourne Florida next month.
shachagra
I'll have to try google sketch. I didn't address the "heater coil" in the main water tank. It is nothing more than a PEX 1/2" hot water tubing that runs through about 15 ft worth in the tank.
lblampman
I use a very inexpensive and easy CAD program called DeltaCAD (it's $39.99) which I found online several years ago (you can download a full working copy for free for a 45 day demo). I use that for 2D layout and dimensioning though I've also done a fair number of isometric drawings with it.
I also use Google SketchUp after I've got things designed in DeltaCAD in order to go 3D. In SketchUp I often literally "build" the project piece-by-piece as I would in the real world; that lets me really get a feel for how things will go together. You can also do very quick SketchUps just to get the feel for shapes, sizes, and whatnot without all the piece-by-piece detail. It's really very versatile (and free!).
Les
MultiSmog
Hola Doug, thank you for the information. There is a vacuum system that uses casettes, it is from Dometic as well.
Saludos
justduck
What a great build and in such a short time. It seems like my major projects take forever.
Question, how about epoxy smell? My wife really objects to my idea of building the head with epoxy coated plywood, remembering the resin smell in the fiberglass sailboat we had years ago.
shachagra
Not even a bit. My wife has a bionic nose and would have reminded me constantly if the smell wasn't to her liking. The entire structure is coated with epoxy, not just the bath. The idea is to seal the wood all around so that you don't get any swelling or contraction of the wood. Wood is super strong but susceptible to decay, coat with epoxy and the decay isn't a factor. I know the fiberglass smell you refer, the older fiberglass boats weren't made with an epoxy. I used MAS epoxy.
shachagra
It once took me 2 years to build a kayak. You have to remember that I was retired, this was my full time job and I had some very capable help for 6 weeks, and probably the most important factor in getting a job done, I had money saved away to buy what I needed, when I needed it.
shachagra
Building the reefer
Here was a pretty easy project that paid big on the trip. We had a small refrigerator and a drop in reefer, sailboat style. We could have done near as well with just the reefer designed with a separate area and access for the cold, not frozen section.
The reefer is simply a big box, lined with 4" sheet insulation (6" to the exterior and bottom) then interior sides of 1/4 MG plywood are shoved inside and joined once in place using epoxy "fillets" (pics are out of order)http://www.clcboats.com/shoptips/stitch_glue/fillets.html to connect the sides. Sealed with a few layers of epoxy and voila.....
The box is 9 cubic feet, much of it under the counter, with a smaller opening than the reefer. I bought a 12V compressor and evap unit http://www.sailorsams.com/mall/refrigerators-indel-build-in.asp which was fairly straightforward. Attach the evap in the box, run the tubing (carefully) to the compressor, hook up to 12V and it froze whatever was put in there. Avoid evaps you have to bend to get in the box- I ruined one first try. ($300!!)
The first picture is England in the winter, note the cozy glow of the fireplace in the back window.
getout
I found your videos on youtube randomly and came here to post them and say you already made it. All I can say is, "wow!"
Thanks for all the info. Looks like it's time to start saving!
lblampman
Hi Doug,
Your thread has been a bit quiet but that doesn't mean we're not still reading and waiting for more! :) I love hearing about your build and how you went about it.
Also, were you able to find out the height to the top of your frame rails? Did you find a photo that shows the steps down to the truck cab?
New question: What size tires are on your truck?
Thanks!
Les
DanoWall
