LJ_24 100 series build thread
LJ_24
About to get Slee'd:D
attachment.php
LJ_24
Just some updates!
The ARB is now installed. I decided to wire the turn signals as well. The ARB has a park light and amber turn signal. Decided I want the dual filament effect so I put some amber LED's in the park light housing so I can have amber park light(like the oem turn signal) and have the amber turn signal flash when I turn.
Also installed some bilsteins on the front end, best comfort upgrade to date! They improve handling by a longshot! Wish I did this earlier
Some offroading(pre-bilstein and pre-arb wiring)..not too serious
attachment.php
attachment.php
LJ_24
Installed some LED light bars on a "homebrew" $12 mounting system from home depot for my ARB. Converted signals in the ARB to DRL and placed CREE bulbs in it. Also installing LED signals in the ARB this weekend when I do my FJC ARB install
LJ_24
Curious... why two instead of one longer unit?
Rob, I wanted to be able to run it off of my fog light harness. At 54w, these are comparable to running the 55w HID kit that I had in my oem fog light housings. So same harness, no wiring needed(besides pluggin the light into the socket) then useable on the oem switch
I will be moving up to a 32" soon or maybe even place the 32" on the roof. I will be using it at Oceano this weekend
preview:
LJ_24
I will be adding camping lights to the hatch for the 100 series, write up coming soon! Tired of loading up the trailer at night and not having enough light when hitching up or removing the trailer
LJ_24
Camping lights, done! Added two 80 series dome light panels to the rear hatch! Perfect setup with 7.5A inline fuse and hidden wiring for a factory look along with some LED panels in the dome light housings
Should I try red LEDs instead?
attachment.php
attachment.php
rtaylor
Nice mod. Install details? Cut and mount in plastic, splice into existing wires or new wirimg with a switch?
Henrybrowne
