I have used those posi-lock connectors in the past and in fact have several in the truck at all times for emerency use. I like that they can be reused but I still prefer to use a soldered connection. I find the posi-lock connectors difficult to conceal after using them.
I also use a set of Channel lock crimpers for interior uses ($30) last you a lifetime and I have never had a joint fail using them. I work on generators for a living and am always repairing damaged harnesses, so a decent set of tools is a must.
