Here's a pic of my rig and trailer for reference. I use the trailer to tow dirt bikes, but I'm slowly adding more adventure trailer capability. My Honda has a pop-top installed by Ursa Minor.
I'm getting a National Luna weekender fridge and hoping to add a dual battery system to get me through longer weekends. Not enough room in the Honda's engine compartment or rear cargo space to add a second battery setup, so hoping to use the National Luna Power Pack setup, installed in the utility box of the trailer. I don't have room in the rear cargo area of the Honda, since the rear seats need to fold down flat for sleeping.
The idea is to run the cables from the main battery, underneath the Honda and out to the trailer hitch, then run another set of cables from the Power Pack (installed in the trailer's cargo box) to the hitch, then terminate both with a quick connect. When I am driving, the Fridge would run off the main battery (I had ursa install a 30 amp power outlet on the Honda), and when camping, I'd run the fridge off the power pack connector.
Some questions:
1. Anyone do this kind of dual battery setup before, where the second battery is located on the trailer? Any tips, impressions, warnings?
2. Since the trailer may get unhitched at times during camping (and also when stored) how to manage the ground connection? Should I ground to the trailer? Any concerns/issues? The trailer is all aluminum if it matters, and will also have a rototpax setup on the inside wall of the trailer to hold fuel and water containers.
3. What about the quick disconnection terminations? I was thinking of using Anderson plugs, but would appreciate feedback.
4. I assume that during storage of the trailer in my garage, I'd need to run a battery tender to keep the battery fresh.
Thanks for any feedback.
Some questions:
