My turn. 1995 Montero SR build thread...
jluck
Time to sell this one
I am going to sell this rig if anyone is interested. It needs a coolant O-ring replaced and I don't have time to screw with it. I would like 1900 as-is and I will through in the OE suspension seat lowers and any other goodies I have for it. The new tires still look brand new, Fancy battery cables included too.
Located in Oregon
What O-ring? The oring in one of the coolant cross over pipes ontop/behind the engine? Yeah, I discovered mine were leaking too... could have been a show stopper... Did you source the o-rings?
jluck
Yep I believe it to be the same one(s). I have not tore in to it to know for sure. I really don't have time to mess with it and I have not looked for replacement O-rings yet.
off-roader
When was the water pump replaced last? The o-ring should have been replaced at the same time. If that was and it's bad, then the water pump, timing belt, and other front end components (belts, tensioners, etc.) should also be replaced.
jluck
I have no idea when water pump was last done. Other maintenance items will be new owners decision.
iStan814
