Silverwulf
Hmmm I wonder what the temp was????
Lol, I was kidding!, Your temp gauge reads 44*![]()
What O-ring? The oring in one of the coolant cross over pipes ontop/behind the engine? Yeah, I discovered mine were leaking too... could have been a show stopper... Did you source the o-rings?
When was the water pump replaced last? The o-ring should have been replaced at the same time. If that was and it's bad, then the water pump, timing belt, and other front end components (belts, tensioners, etc.) should also be replaced.
