Overland Hadley
on a journey
So these campers dont come with a Shore Power Plug out of the fuse box??
A shell is an empty box is an empty shell.
My mistake, I thought the inside wasnt finished, but the wiring and items like that were already run
I love your use of the Blue Performance Cabin Bags,
Perhaps the rig as a whole should be dubbed Humpback Hadley....or some such.
	Or backfeed power via an existing circut eg. the solar provision: (hook up to the Red and Black, might need to add a fuse in the distribution panel to complete the circut)
After spending some time in the camper I decided to go ahead and install a Fantastic Fan. I went with the 5000 model, as it has the thermostat but no other fancy do-dads. I did not realize that there is no "on'' switch on the thermostat, so currently the fan does not work below 40* and that is not much of a help for four season camping. I now have the switch to bypass the thermostat, just need to wire it in.
I wasn't aware of this, good to know while evaluating which model to go with. I would assume this likely affects all models above the 4000R.
	If I was installing a new one, I'd simply go with the 4000R. It has dual directions for the fan and a simple on/off switch and not all the gimmicks
