Metal Storage Drawer/Box
DevEmp
I'm curious if anyone has a source for metal storage boxes like the Tuffy Unlimited Security Drawer but just not as long? The Tuffy Unlimited box is 20" long, and I'm looking to find something a bit more shallow, say 12 or 14". Something similar to the 3 or 5 drawer box at Cabelas but obviously wide enough to take up the space in the back of a Jeep Unlimited.
Any help would be appreciated.
Robthebrit
The problem with those cases is they are steel and over time they will rust and have problems. If they are going to be exposed then stick with aluminum, you also get a weight savings. The bed of a truck is probably the worst place for power coated steel as it gets banged and knocked continually which exposes bare metal.
Personally I have always used Zarges cases, you can get them in all sizes even custom made sizes. Fortunately when I got the camper mog it already had all Zarges storages boxes, one was missing so I replaced it, but the existing cases are all 19 years old and been on the truck for its entire travels and still work like they are brand new. If I buffed them they would also look brand new.
One down side is most of them are top opening so they work as a chest and not as draws, If you mounted one sideways it would probably leak. You can get lots of insets for the cases to compartmentize them.
I am considering getting another and modifying it to hold a running Honda EU2000 generator.
You can find suppliers all over the web.
Rob
jwolfuo
I'm in the process of doing as much research about this subject and finally found someone doing an XJ as well. When your wifes truck is done could you post a few pics.
Thanks
I also have an XJ and have been looking for an option.. Did you manage to find anything suitable?
Petersmithinak
