Northern Explorer
You can add a simple switch & resistor to it as well to make it a 6speed (a reduced speed from each main speed), I did that in my current FWC because the low isn't really that low.
I agree that the low speed isn't low enough. Can you provide a link so I can see how this is done?
Nathanael: I don't think you will find the thermostat issue much of a problem. Not to often are you going to want sub 40 degree air blowing down on your head or vise versa have all of your heated air be sucked out of the camper on a sub 40 degree day. When cooking in that kind of weather you will find that opening one of your bottom turnbuckle hatches and the roof vent (fan off) and maybe a crack in a window is usually all it takes to create enough of a fresh air draft unless you are running both burners on high.
