One common belief is that full size trucks aren't a good choice for off-road adventures.  They're too big for tight trails, use too much gas, and, well, lack the mojo of a Jeep or Land Rover.  But is this true in 2012?
The next couple of posts include dimensions and capacities of 2012 trucks from Jeep, Toyota and Dodge. My observations:
--The Dodge pickup is indeed wider than the Jeep and Toyota pickup. The difference is less than 6 inches, the width of an outside mirror.
-- The Jeep is shorter than the two pickups by almost 3 feet. That's good for maneuverability, but bad for cargo capacity. Piling stuff on the roof creates its own problems.
-- The Dodge has a tighter turning circle than either the Jeep or Toyota.
-- The Dodge has a V8, so it's rated lower by 2 mpg in city driving. For highway driving, the rating is about the same, with Toyota ahead by 1 mpg. The range of all three vehicles is the same because the Dodge has a bigger fuel tank.
-- The Dodge has 1400 lb capacity for cargo, Toyota 1200, Jeep 1000.
-- The Dodge is way ahead in towing ability.
Conclusion: These 3 vehicles are close to each other in most dimensions. Each has its advantages. If I were looking for a truck to use with a camper, then I'd give the Dodge (and similar short wheelbase full size trucks from Ford and Chevy) serious consideration.
