I've left the Toyota Fold, AKA my Montero Build Thread
red87
It ended up right around $600 from Sierra Expeditions. I won't bother with the torsions until I get a bumper. I went with the Nitrocharger Sports and the regular rear springs, not the expedition-weight ones.
red87
Got the new suspension on today! Can't post pictures from my phone so I'll get those up later
red87
I didn't get too many pictures of the install as its pretty straight forward. The only trouble I had was with an obscenely tight nut on the lower end of one of the rear shocks. The driver side rear spring went in super easy and I had to use the factory jack to push down the passenger side of the axle to slip that one in. All in all, not too bad. Ride is much better now and it holds weight very well. I was driving around the past day with like 200 lbs in the rear and that felt better than stock with no load. On a related note, I now have a pair of stock Gen 2 rear springs for sale so tell your Gen 1 friends :)
Check out how much bigger the OME shocks are than the stock adjustables:
In their happy new home:
Rears installed:
Forgot to take comparison pictures before I installed them. They're supposed to give me 2" more travel in the rear. The front travel is unchanged.
How it sits with ~200 lbs of tools and stuff in the back with the torsions cranked a bit:
I'll get an unloaded picture later today. It looks very close to stock rake, just higher all around.
Looks good! I like the front lifted as you have. Do you recall about how much you needed to lift it?
Also, do you know if its necessary to replace all four of the adjustable shocks at the same or can the back two be replaced first and then the front two? I haven't checked the system too closely yet to see if there is a valve anywhere for the shock adjusters.
red87
Thanks! The front is roughly 1.5" higher than stock. 12 turns on the adjusters.
The shocks have electronic adjusters on top, no valves anywhere. However, I don't know how the circuit works so I don't know if unplugging a couple will affect it or not.
red87
Side shot with no weight in the rear. Not a great picture but hopefully it'll show the rake:
I literally get that much squat with about 600lbs of gear in the back of my rig with the OME heavies. It also rides like a dream with that much weight...
attachment.php
attachment.php
I just need to crank the torsions in the front to somewhat level out the truck, still quite stink bug....
red87
Just got back from a fun desert trip out by Ridgecrest and Lake Isabella. The new suspension worked fantastically! The auto adjusting valving in the OME shocks could really be felt and made a big difference in ride quality.
red87
Also got this nifty little guy for my birthday:
HIGHLY recommended accessory. Fits nicely in that bin under the passenger seat and makes airing down so much faster.
Inyo_man
Don't piss down my back and tell me it's raining.
The OEM suspension has won me over as well. When the rig is loaded, the suspension really starts to perform at its peak.
Where were you exploring on your trip?
red87
CYi5 and I were out around Lake Isabella and Ridgecrest. Went to the Holly Ash Cleanser Mines, Burro Schmitt's tunnel, Bickel Camp and a couple other places.
Inyo_man
Those are fun day runs with the family. Is Jose still care-taking at Bickel Camp? He is a kick in the pants and a wealth of knowledge about the area. Did you take the walk all the way through Burro Schmitt's tunnel...that is a fun adventure. Did you happen make it up into the forest around Lake Isabella, I was wondering what the flow rate was on the rivers and if they were passable yet. Any photos?
sunnyaz
