Overland Hadley
on a journey
Nice idea, I'd would like to do something similar to haul extra fuel. I assume the jack brackets and structure behind can take that dynamic load?
I was also thinking it would be nice if the location of the foot/roof steps on the rear of many FWCs could be used for an AT can holder to carry fuel/water.
James
Personally, I would not mount a jerry can to only the rear wall of a FWC.
I do not know the exact strength of the frame members in the rear wall of the camper, but it is all lightweight aluminum. And the dynamic loads of a full jerry can on a rough road will be high. The weight of a person standing on a step would be static, but the forces generated by the weight bolted to the frame bouncing around on a rough road would be dynamic. Granted, the corners are obviously strong, and the FWC factory mounts an air-conditioner on the passenger side of the rear wall. So it might be okay.
I designed my mount so the weight is held by the supports under the holder. Some of the weight will be held by the screws in the jack brackets, but it is supported by the bars that are through bolted to a plate inside the camper. The photos in my post below might do a better job describing the support frame.
Feel free to ask any more questions.
Thoughts, ideas or questions are always welcome.
(close to) Finished the AT jerry can mounts.
Here are some photos from mid way through mounting them up, it started pouring rain at the end so I do not have any photos of the (almost) finished mount. I say almost finished because I might put an aluminum plate on the bottom of the plywood, because I am currently using a washer to fir out the underside of the plywood to even it up with the siding trim strip.
It is super solid, I can hang off it with little/no deflection. Good as it will see a heavy dynamic load when the cans are full.
All hardware is stainless. :ylsmoke:
Passenger side:
Drivers side:
Interior plates:
Made and installed the shims on the aluminum bars that support the jerry can holders. Much happier now.
Stood on the one mount and it held just fine. Because the jerry can mounts can now double as a step, I am reconsidering the layout of folding steps on the back of the camper.
I now consider the jerry can holders finished. :ylsmoke:
