Post your Mitsubishi Pajero Pics
Imnosaint
Gone Microcamping
Thanks, I appreciate it. To answer your question, with 17x7.5 FJC wheels on a Gen II the track is very similar to the stock 15x7 SR wheel. The FJC wheels are slightly wider, and that width actually is mostly inboard. However, I have not had any clearance issues. Granted, the tires I run are fairly narrow so if you flexed (ha! flex on a Montero) a larger tire on the FJC wheels it may rub.
Okay, good to know. Looks like the offset of the 7.5 works to the favor of the spacers, an issue that's been bugging me for awhile now. Thank you.
DavidG
If you could find them, I would run the factory Gen III steel wheel. They look very similar and are more tire-size friendly. 16x6.5, IIRC. Perfect for a 255/85-16!
Imnosaint
Gone Microcamping
That'd be ideal. If we were in Japan or Australia, no big deal.
DavidG
I recall seeing the steel wheels in the US on Ebay years ago. They may be the factory non-alloy spare.
DavidG
I like the look of stage 3 with the TSLs.... but I'm a Louisiana boy!
How'd the truck handle that size RTT?
Sorry, missed the RTT comment. It handled it fine on and offroad...and only with two Thule bars. That was a large tent. Easily two or three adults. I sold it to Brad (expo handle: Chuckles) who ran it on his 4wd Chevy van for a while. Incidentally, he just sold the van.
That size tent has been a consideration...But, I'm leaning towards an Oztent or other fast erecting tent. It'd be more useful as an off vehicle shelter if we ever needed to get out of rain or the sun to fix lunch or something.
DavidG
A ground tent is obviously much more flexible and easier to deploy in a variety of circumstances. I really liked the RTT and slept great in it. Some of the most comfortable nights in the woods were in that RTT. Snow, rain, etc. But, once you set up the RTT you are not going anywhere with your vehicle...you can always leave the tent. The kids were not as interested in the RTT after the novelty wore off. I found I was using the RTT for solo nights and for those I could sleep inside my rig. Plenty of room for one!
KIRK!
Amateur Philosopher
Just painted the wheels that came with my new rig, but I think I'm going to powder coat the stock cast aluminum wheels black and run them instead.
red87
Be careful powder coating the wheels. I've heard that the heat process can weaken the wheels. Granted, that's Internet hearsay but no one wants broken wheels.
DavidG
DavidG,
How did you plug up the holes from the bodywork?
You will have three rows of holes to contend with.
The first row is over the wheel wells and across the middle of the doors. I used black plastic body plugs over the wheel wells and a nice, premium black rubber body molding to cover the holes on the doors.
The second row is toward the bottom of the door. I used black body plugs for these. You can't see them very wheel on a dark vehicle. They hide rather well in the angle/shadow.
The last row are along the lower rockers. I used a sturdy black textured tape to cover the holes.
The biggest challenge is removing the double sided tape that helps hold and seal the panels to the body. Get a 3M Stripe Removal Wheel. You use it with a drill. They are expensive but worth every penny.
On a dark vehicle, the end result is great, IMO.
MAX1MVS
I only have two rows of holes (actually, I just checked and I have the 3 rows, just missing the holes above the wheels). That adhesive was a royal PITA to get off...I'll have to track down some plugs. Any specific tape for the bottom row, any closer pics of the area?
Thanks!!!
