Slide out trailer kitchen
Ranchero
Wanderer
I started with couplerss like these: LINK I also have a ball valve. The problem was if someone disconnected the hose with the ball valve open and pump on, it would blow water everywhere. I ended up changing to garden hose quick couplers, with auto shut off.
Thanks Woods
mbuckner
I like that kitchen ......
Have you had trouble getting the transparent propane tank filled? Or do they use
the regular fittings?
Best regards,
Mike
Woods
They are USA and Canada DOT approved and use standard fittings.
Best deal I found was from Uhaul.com (of all places)
Have you had trouble getting the transparent propane tank filled? Or do they use the regular fittings?
Best regards,
Mike
XJINTX
VERY NICE!!!
How do you get water pressure... is it the Triton or onboard pump?
man I wish I had your skills!!!
jordanP13
