Slide out trailer kitchen
I started with couplerss like these: LINK I also have a ball valve. The problem was if someone disconnected the hose with the ball valve open and pump on, it would blow water everywhere. I ended up changing to garden hose quick couplers, with auto shut off.
Thanks Woods
I like that kitchen ......
Have you had trouble getting the transparent propane tank filled? Or do they use
the regular fittings?
Best regards,
Mike
They are USA and Canada DOT approved and use standard fittings.
Best deal I found was from Uhaul.com (of all places)
Have you had trouble getting the transparent propane tank filled? Or do they use the regular fittings?
Best regards,
Mike
VERY NICE!!!
How do you get water pressure... is it the Triton or onboard pump?
man I wish I had your skills!!!
Deputy Dan
